Burning Question, Request for info |
omoore3 |
Feb 21 2003, 08:11 AM
Newbie Group: Members Posts: 6 Joined: 19-February 03 Member No.: 323 |
As I mentioned in an earlier post, I just got given a 2.0 '74-75? project car. Thanks to a quick response, I did find the fuel --under the front.
I feel like an idiot asking this--I have owned 2 356s, a 911 SC Targa, a 944 and two 928's. But for the life of me I can't figure out how to open the back trunk? Secondly, the interior of the car and the front trunck is stuffed with pieces that have been removed. Can anyone recommend a book that would have pictures of parts in it so I can begin ctataloging this mess? Many thanks in advance Oliver |
seanery |
Feb 21 2003, 08:30 AM
The back trunk has a vw style push button release and lock unless someone put a PORSCHE reflector between the tail lights. If that is the case you probably have a solenoid somewhere, i dunno where though.
There is a book, I don't know where mine is: How to restore and modify your 914 Porsche This might be a good starting place. |
omoore3 |
Feb 21 2003, 08:38 AM
Thanks for the quick reply. yeah, there is a Porsche reflector. As for a solenoid, this is going to be a real easter egg hunt as the wiring harness is a hash.
I will get that book. Oliver |
omoore3 |
Feb 21 2003, 08:56 AM
Well, I just went out into the yard and ripped the Porsche reflector off and discovered that there is no key hole. Odd that there wouldn't be a mechanical way to open it. What would you do with a dead battery?
Oliver |
brant |
Feb 21 2003, 09:19 AM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The factory hole, must have been filled...
sometimes when people install reflectors.. they use a mechanical pull cable instead of a solenoid..... 2 places you should look are: below the trunk for a cable pull.. or in the engine bay for a cable pull... brant |
seanery |
Feb 21 2003, 10:07 AM
REASON 368 not to buy a 914 with a PORSCHE reflector stuck on it!
boxstr |
Feb 21 2003, 10:33 AM
Look directly in the center of the rear bimper at the bottom and under the car near where the muffler would be. Some have added a cable or chain, it is a mechanical failsafe for dead battery or failed solenoid.
Craig IN DAMP CAMP 914 |
Jeffs9146 |
Feb 21 2003, 10:50 AM
you ripped off the reflector??? Bummer!
I had a buddy who drilled a small hole in the center floor of the trunk and used a coat hanger to pull down the plunger on the solinoid when an accedent cut his power wire. |
Crawf |
Feb 21 2003, 11:18 AM
Newbie Group: Members Posts: 24 Joined: 20-January 03 From: Berkshire, England, UK Member No.: 171 |
I have a pull system in the engine bay, located passenger side, hidden away up towards the front of the trunk above the back of my carb.
Alfred |
Feb 21 2003, 11:26 AM
Unregistered |
QUOTE(omoore3 @ Feb 21 2003, 06:11 AM) Can anyone recommend a book that would have pictures of parts in it so I can begin ctataloging this mess? Many thanks in advance Oliver The Haynes 914 repair manual is a must have and you might also want Dr. Brett Johnson's book "914 and 914-6 Porsche A Restorer's Guide to Authenticity". They are both available online at Pelican Parts or Amazon.com . Alfred |
Jeffs9146 |
Feb 21 2003, 11:30 AM
You can see my pull cable that goes from the plunger to the engine comp. I have used it many times durring the restoration.
Jeff |
Feb 21 2003, 11:33 AM
Group: Posts: 0 Joined: -- Member No.: 0 |
Burning? This might cool that question down (IMG:style_emoticons/default/laugh.gif)
(IMG:http://www.computerpranks.com/download/images/ads/preparationh.jpg) |
Lo-Fi Version | Time is now: 19th May 2024 - 08:51 PM |
