Running Hot!, What can I do? |
newto914s |
Apr 18 2006, 04:05 PM
Senior Member Group: Members Posts: 561 Joined: 16-February 04 From: Thornton, CO Member No.: 1,663 |
I just finished Tunning the car, and it's still running hot. Today on the highway the CHT were getting past 375, up to 400. The only way to keep them below was to not drive, oast as much as possible, and not go faster than 55 for to long. And that's no fun at all. (IMG:style_emoticons/default/sad.gif)
What can I do? Here is what I know. Timing good, cooling flaps open, valve clearance set, and it's not running lean. What else is their? |
ArtechnikA |
Apr 18 2006, 04:13 PM
in what gear are you trying to go 55?
with stock gearing and tire size, 55 is much too slow for 5th. high CHT is a symptom of insufficient cooling air - which can be caused by lugging (fan speed too slow for the applied load). it can also be a symptom of that shredded paper towel that got sucked into the fan and deposited onto the tops of the heads, or a garbage bag sucked into the fan... 5th is a track gear, or a fuel economy gear. if you're trying to cruise at 2000 rpm in top, you'll see high CHT... |
lapuwali |
I typically saw 350-375 with a stock cam and heads (on a 1.7), up to just touching 400 pulling up a long hill. This is "normal" for a stock engine. Headwork, particularly to the exhaust side, and a better cam will reduce head temps, according to Jake. The stock engine, however, will run about where you are. If you run well over 400 for any length of time, or run that kind of temp on a flat road, then you still have some problem.
I'd only see 310-325 at surface street speeds (up to 35-40mph), btw. On the highway, keeping it under 375 meant running in 4th until I was running at pretty illegal speeds. |
BMartin914 |
Apr 18 2006, 04:15 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
Do you know what your oil temps look like?
Are you sure your CHT gauge is correct? Calibrated? Have you searched for threads regarding the VDO CHT gauges and their fluctuation in readings dependent on the outside air temp? If you know all of the above is good and the things you mentioned prior (timing, flaps opening correctly,etc.) leaves, debris, mouse nests on the cooling fins comes to mind. It is a little time consuming, but better than dropping a valve, I would suggest pulling your tin off and visually inspecting your heads and cooling fins. Check your impeller too for missing fins or gunk buildup that may be preventing decent airflow. The answer is there somewhere. You also might consider putting the gauge sender on another cylinder and seeing what type of reading you are getting. If your oil cooler is restricted, it may very well be restricting airflow to the cyl heads, but that would also cause high oil temps if you don't have an external cooler. Put the sender on the other bank and see what you get. I had the opposite issue - very high oil temps, but good head temps. Everything was kosher, but the temps were still high - I installed an oil cooler, but that obviously won't solve your problem. |
newto914s |
Apr 18 2006, 04:29 PM
I was in 4th and 5th gear. Stock gearbox. I know about the lugging issue and 5th not providing the greatest cooling, but 4000rpms in 4th appeared to be making things worse.
Gauge is a Westtach, and calibrated to 75deg. which is very close to what it was out there today. I think if I was not fethering the gas so much it would have settled in around 400deg in 4th. About dirt and nests. The engine was just pulled in august(for headwork) and the passages, oil cooler, and fan are clean. |
Joseph Mills |
Apr 18 2006, 04:33 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Is this a carbed engine? If so, do you know the size of your idle/main jets?
Inspect all your engine tin and make sure you're not missing any pieces. Duck tape over any empty holes in the tin. Are both of your air deflectors in place beneath the firewall? .. |
Apr 18 2006, 04:40 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
any crud on the cylinders? you'd be surprised at how much crap one can find in the cooling fins ...
(IMG:style_emoticons/default/wink.gif) Andy |
newto914s |
Apr 18 2006, 04:46 PM
D-jet all tins are in place as well as deflectors. No crud between Cylinders. They are dished bus pistons, but I would think that to lower the heat.
Apr 18 2006, 04:55 PM
D-jet all tins are in place as well as deflectors. No crud between Cylinders. They are dished bus pistons, but I would think that to lower the heat. are you *sure* the cooling flaps are working? (IMG:style_emoticons/default/idea.gif) Andy |
newto914s |
Apr 18 2006, 05:05 PM
Yes (IMG:style_emoticons/default/confused24.gif)
When I had it apart I read through the threds about how the flaps work, and am pretty sure I got them back together correctly. The spring is on the ,and if standing on the driver's side, I have to rotate the flap bar CW against the spring in order to close them. There are 2 underside deflectors right. |
Apr 18 2006, 05:07 PM
newto914s |
Apr 18 2006, 05:37 PM
Only if you consider a 75-76 rubber bumper a
QUOTE big sweeper front air dam .Attached image(s) |
So.Cal.914 |
Apr 18 2006, 05:39 PM
I see you are in Puerto Rico, I am east of Palm Springs and our air temps are in the 90's which makes mine run hot. (125 degrees makes it run even hotter) Did someone sudjest you change to a hotter plug when you did your tune-up or change to a electronic ignition/coil ? (IMG:style_emoticons/default/smoke.gif)
Ok I see you did something to your car. What ever that thing was that you had hooked up to your car, did you notice this rise in temp after you did that? If so I would look into what ever changes you made to your car before you look for new gremlins |
Zaney |
Apr 18 2006, 06:06 PM
Deuchland en der Haus Group: Members Posts: 461 Joined: 1-March 04 From: Engine 11 Redmond, WA Member No.: 1,738 Region Association: Pacific Northwest |
Andy,
How much does the LE style front air dam cut down on the fresh cooling for the engine? (IMG:style_emoticons/default/beer.gif) Nate |
newto914s |
Apr 18 2006, 06:13 PM
So.Cal.914 that was accually just a wide abd O2 sensor. It's off now and really help a lot. Rightnow the car is in N Kentucky where the weather could not be more perfect for driving a teener.
bd1308 |
Apr 18 2006, 08:22 PM
So.Cal.914 that was accually just a wide abd O2 sensor. It's off now and really help a lot. Rightnow the car is in N Kentucky where the weather could not be more perfect for driving a teener. Heh. It's somethign about KY I guess. Mine isn't working either. You still in KY? b |
Jake Raby |
Apr 18 2006, 09:57 PM
Most importantly:
Where is the CHT sending unit attached to the head? |
reverie |
Apr 18 2006, 11:01 PM
Senior Member Group: Members Posts: 783 Joined: 14-March 03 Member No.: 427 Region Association: None |
Other than running hot, how does it run?
Any other symptoms?.. misfiring, surging, etc? (This topic has come up before, exactly the same problem you're having, and as I recall we were unable to determine a cause that time. I hope we find it this time.) |
Joe Ricard |
Apr 19 2006, 06:16 AM
Exactly why do you believe it is not running on the lean side? Don't take much
My carbed engine ran MUCH cooler after reaming out the idle jet size from 50 to 53. 55 seemed too big as evidenced by A/F gauge. WHat exactly is timing set correctly? what is your dwell and what metod are you using to set timing. is your advance and retard funtioning on the distributor? |
newto914s |
Apr 19 2006, 04:20 PM
To anwser the last couple of questions.
Brit, I'm now in PR again. Jake, Westach CHT gauge, sender under #3 spark plug Reverie, other than temps, it runs great, slight bog off the line, but smooth power straight to Redline. Very light popping on over-run, but you have to listen for it. When it starts to get around 375+ their is a small buck or hesitation on transitioning from decel to accelerating. And this doesn't happen when temps are around 350 Joe Ricard, I don't think it's running lean because I tunned it, and my AF gauge says it's not going above 13.8 anywhere from idle to redline. Dwell is set to spec 44°-50° and timing is 27° BTDC. I'm farlty sure the advance is working on my dizzy. The first times I tried to time the car I forgot to plug the dizzy advance and the car didn't sound right at all. |
Lo-Fi Version | Time is now: 7th May 2024 - 05:37 PM |
