the mystery holes, outside by the rear window under roll bar |
sk8kat1 |
Apr 19 2006, 08:45 PM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
there are 6 holes under there with plastic plugs in them .... there are nuts attached inside the roll bar -- what are they for? (IMG:style_emoticons/default/confused24.gif)
Eddie Williams |
Apr 19 2006, 08:48 PM
Senior Member Group: Members Posts: 822 Joined: 30-December 02 From: Nederland, TX Member No.: 55 Region Association: None |
ski rack
thewheel69 |
Wazabi 1.8 Group: Members Posts: 54 Joined: 14-December 05 From: Fort Collins Member No.: 5,275 Region Association: Rocky Mountains |
I'm by no means an expert here but I believe they were for some kind of luggage/rack mount... there actually is a bike rack that mounts to these. I know, I have one!
Hope this helps... I'm sure others more knowledgeable will pipe in... |
914-8 |
Apr 19 2006, 08:55 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
yes, they are bolt holes for racks.
also, look on the windshield header - under the rubber, you can see two plastic rectangular plugs (one on d side, one on pass side). Those are removable, leaving holes to mount the front part of the rack! |
So.Cal.914 |
Apr 19 2006, 09:00 PM
The ski race was a very clean install. One small piece mounted under roll bar and the other mounted to the rear bumper thru the tow eye hole. I had one too.
(IMG:style_emoticons/default/smoke.gif) |
sk8kat1 |
Apr 19 2006, 09:57 PM
cool.. well my plan is to fabricate and attach a mouting plate using those holes .. so I can install a 3rd break light w/o drilling into the roll bar itself... at least that's the plan (IMG:style_emoticons/default/smile.gif)
iamchappy |
Apr 19 2006, 10:07 PM
I had a ski rack and used it too, I had it sitting in the basement workshop for years why I tossed it I dont know.
Eric_Shea |
Apr 19 2006, 10:11 PM
Ski rack would be cool...
brer |
Apr 19 2006, 10:44 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
like zees.
Joe Bob |
Apr 19 2006, 10:45 PM
Mount the third tail light on the engine grill.....
Apr 19 2006, 10:52 PM
funny how the same stuff comes up every other month or so ...
while it is true that the *aftermarket* ski rack uses those holes to mount brackets, that is not their original purpose. the holes are part of the factory "Hohlraumversiegelung" system and are used to inject insulation foam into the hollow parts of the 914 frame. see this old thread, or, just do a search on "Hohlraumversiegelung" http://www.914world.com/bbs2/index.php?show...1&st=&p=entry (IMG:style_emoticons/default/beerchug.gif) Andy |
gregrobbins |
Apr 19 2006, 10:57 PM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
funny how the same stuff comes up every other month or so ... while it is true that the *aftermarket* ski rack uses those holes to mount brackets, that is not their original purpose. the holes are part of the factory "Hohlraumversiegelung" system and are used to inject insulation foam into the hollow parts of the 914 frame. see this old thread, or, just do a search on "Hohlraumversiegelung" http://www.914world.com/bbs2/index.php?show...1&st=&p=entry (IMG:style_emoticons/default/beerchug.gif) Andy Are you sure? There are threads for a 10mm bolt. If the holes were to inject foam, they would not need bolts. |
Apr 19 2006, 11:25 PM
Are you sure? There are threads for a 10mm bolt. If the holes were to inject foam, they would not need bolts. no, i'm not sure, but the factory was ... btw. they're supposed to be plugged and not left open ... (IMG:style_emoticons/default/cool_shades.gif) Andy |
East coaster |
Apr 20 2006, 05:49 AM
Senior Member Group: Members Posts: 1,673 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
The pictured ski rack in the previous post is an aftermarket rack. I had a factory ski rack that mounted to these holes and the windshield frame as mentioned. It was pretty cool, it's a thin tubular chrome rack front and rear with leather straps for the skis. I thought about keeping it just 'cause it was cool, but I sold it to someone who would actually use it. I can't find any pics of it...sorry!
davep |
Apr 20 2006, 08:25 AM
Yes, the threaded holes were part of the accessory mount system as are the plastic receivers in the windshield frame. However, do not remove the plastic receivers to use the front mounts. The plastic pockets are there to protect the windshield frame. Do not leave the racks in place for extended periods. The tongue on the front of the rack displaces the rubber seal, and extended use will cause permanent deformation of that very expensive seal.
IronHillRestorations |
Apr 20 2006, 08:52 AM
Apr 20 2006, 10:47 AM
Sounds like a good explanation, except there isn't any foam inside the top piece of the roll bar. and you should be thankful for that! it was a factory (dealer?) option to have them actually add the spray foam, it was not done by default. so, unless the original owner of your car paid extra to have his car all foamed up, you won't have any. BUT, the important point here is that there are quite a few access holes on the car that were supposed to be used for injecting the foam, plus there's a list of points where they would have *drilled* holes to get into cavities ... (IMG:style_emoticons/default/wavey.gif) Andy |
davep |
Apr 20 2006, 12:18 PM
Andy, where did you get this information? I've never hear, nor read that anywhere in the past thirty years.
Aaron Cox |
Apr 20 2006, 12:57 PM
anyone need a ski rack?
i got one on my shelf. |
JeffBowlsby |
Apr 20 2006, 01:08 PM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Dave P, the foam injection diagram is from DGVWP buch, see the post Andy referenced. Here is the factory sk-rack with mounts, hey I like the ability to add multiple photos in s each post!:
Lo-Fi Version | Time is now: 17th May 2024 - 03:44 PM |
