Things I should replace, what's critical |
Hammy |
Apr 20 2006, 06:33 PM
I know there are a million threads like this but I can't find any by searching, so I'll make my own.
Before I put the engine back in I'm wondering what I should replace, stuff that'll save me from pain down the road. I don't have the knowledge or skills to dig into anything deep and complicated, so any of that is off the list. (IMG:style_emoticons/default/slap.gif) So far I already have: Alternator belt, SS fuel lines from Chris And plan on ordering: Thermostat cable, accelerator cable.... I know there must be more (IMG:style_emoticons/default/rolleyes.gif) What about CV joint gaskets, critical? So, what else? My budget is pretty small, I can't afford to get into the "while I'm in there...." mindset (IMG:style_emoticons/default/laugh.gif) |
redshift |
Apr 20 2006, 06:36 PM
Yes! Please take your CVs off the axels, and wash them on a delicate setting, with a mild detergent.
(IMG:style_emoticons/default/smile.gif) M |
Hammy |
Apr 20 2006, 07:04 PM
How many CV gaskets are there? PP says 4 per car but diagram only shows one per side...
Joseph Mills |
Apr 20 2006, 07:24 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
How many CV gaskets are there? PP says 4 per car but diagram only shows one per side... One gasket for each CV. But since you're not removing the outer CV's located somewhat inside of your suspension trailing arms, you only need 2 for the inner CV's at the tranny. .. |
Eric_Shea |
Apr 20 2006, 07:40 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Rubber brake hoses. You don't want to do this with the engine in the car.
Hammy |
Apr 20 2006, 11:11 PM
So.Cal.914 |
Apr 21 2006, 12:34 AM
Sense you are asking I made it a point to replace the clutch cable, throw-out bearing and shift linkage bushings (especially at the firewall). Better now than later. Just my opinion. (IMG:style_emoticons/default/smoke.gif) |
Hammy |
Apr 21 2006, 12:52 AM
Sense you are asking I made it a point to replace the clutch cable, throw-out bearing and shift linkage bushings (especially at the firewall). Better now than later. Just my opinion. (IMG:style_emoticons/default/smoke.gif) I was thinking shift bushings too... It appears my rear ball cup bushing that goes in the shift rod head is all metal so I assume that one doesn't need replacing (?). |
solex |
Apr 21 2006, 07:12 AM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
The rear ball cup bushing is inside that metal piece and it is made of plastic (or some other soft material). If there is slop there I would replace it. Also the fire wall bushing for the shifter and if the shift coupler bushing are in bad shape you may want to replace them as well.
Pelican has a nice package deal for all fo the shift rod bushings. |
Lo-Fi Version | Time is now: 6th May 2024 - 11:18 PM |
