This bad karma wont die!, Why intermittent start? |
Toast |
Apr 21 2006, 12:01 AM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
Ok. I was goint to supprise everyone at the G&R swap meet in Riverside on the 30th, but I need your help before then because I WANT TO DRIVE DAMMIT!!!!
Suprise is: I GOT MY 914 BACK FROM THE BODY SHOP! Before the questions start about how it turned out, well, lets just say that the color matches and leave it at that. Now, my problem is that sometimes it wont start. Just sometimes. (IMG:style_emoticons/default/WTF.gif) I've had it back from the shop for a week now and have only got to drive it 4 times, less than 7 miles each. :pout: It seems that it wont start in the mornings, when its cooler, but will start fine in the afternoon (when the weather is warm) after it's been sitting outside all day. It goes reer-reer-reer-reer as long as i'm turning the key. I hear the fuel pump. I have 11 volts on and 9 volts when turning over. Just seems like the spark is missing for fire. (IMG:style_emoticons/default/confused24.gif) I don't know for sure, but it is probable that the body shop did not disconnect the battery when welding was done. (IMG:style_emoticons/default/slap.gif) Spark plugs? Tune up? Ground wire? Idiots at body shop screwed something up? Not enough battery juice? Board? Brain? Not being driven for 2 1/2 months and pouting? But why sometimes does it fire right up? Ideas or suggestions? (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 08:13 AM |
