Can I shorten the main air jet?, Modifying Dellortos |
groot |
Apr 21 2006, 05:30 AM
Dis member Group: Members Posts: 894 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
I've got a set of Dells and am trying to package some velocity stacks on them. But, the tall main air jets are in the way. I have several differest size main air jets and some are short (~15mm), others are tall. The 180s are tall (~60mm).
So, is there any issue with shortening the tall main air jets? I would cut a slot in it so I can still remove the jet stack. |
jr91472 |
Apr 21 2006, 07:21 AM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Are the stacks really large? Mine "stardard" 2in stacks fit without any problem.
(IMG:style_emoticons/default/piratenanner.gif) btw, keep us posted on the Runnoff's this year. I had a blast watching you guys. |
groot |
Apr 21 2006, 07:28 AM
I'm working with Spunone to make some stacks... they will be very short and wide.
Thanks for the support. This year will be much better for me. I'll have an engine that makes more that 120 horsepower and should last more than 3 or 4 laps. |
Aaron Cox |
Apr 21 2006, 10:25 AM
if they are like webers, there are tall jet holders and short ones. Im going to have the same problem with the stacks... the tall ones are there * i think* to aid in the stack getting clogged..... thus a taller snorkel
Lo-Fi Version | Time is now: 7th May 2024 - 10:51 AM |
