Fixed tranny oil leak from speedo angle drive., finally... |
olav |
Apr 22 2006, 12:43 PM
Senior Member Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
Had transmission oil leaking out of my speedo angle drive. Just a little drip out of the end, then it progressed to leak into my speedometer cable and down it.
Finally figured out the problem. There is a seal, not the o-ring, right where it speedo angle drive screws into the speedo transmission guide, the aluminum cylinder. The seal goes around the speedo transmission gear shaft. When I took the gear and guide out that little seal was trashed. Took it out put in a new one and now no more leak. (IMG:style_emoticons/default/clap56.gif) That was a pesky leak and the tranny oil would go on my muffler and make a mess. Just thought I'd mention this in case anyone else is having an issue like this. Sorry, no pics because I forgot my camera... (IMG:style_emoticons/default/sad.gif) |
Spoke |
Apr 22 2006, 09:07 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Where did you get the seal and o-ring? I have the same issue and was going to start a thread about fixing it.
Spoke Attached image(s) |
ThinAir |
Apr 22 2006, 09:19 PM
Best friends Group: Members Posts: 2,542 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Where did you get the seal and o-ring? I have the same issue and was going to start a thread about fixing it. This is exactly why it such a great thing when you find a solution and post it! It's only a matter of time before someone else has the same problem and a search can then provide a quick solution. Congrats on finding the problem and thanks for posting it! Now, we need part numbers! (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:54 PM |
