Fixed tranny oil leak from speedo angle drive., finally... |
olav |
Apr 22 2006, 12:43 PM
Senior Member Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
Had transmission oil leaking out of my speedo angle drive. Just a little drip out of the end, then it progressed to leak into my speedometer cable and down it.
Finally figured out the problem. There is a seal, not the o-ring, right where it speedo angle drive screws into the speedo transmission guide, the aluminum cylinder. The seal goes around the speedo transmission gear shaft. When I took the gear and guide out that little seal was trashed. Took it out put in a new one and now no more leak. (IMG:style_emoticons/default/clap56.gif) That was a pesky leak and the tranny oil would go on my muffler and make a mess. Just thought I'd mention this in case anyone else is having an issue like this. Sorry, no pics because I forgot my camera... (IMG:style_emoticons/default/sad.gif) |
Spoke |
Apr 22 2006, 09:07 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Where did you get the seal and o-ring? I have the same issue and was going to start a thread about fixing it.
Spoke Attached image(s) |
Lo-Fi Version | Time is now: 3rd May 2024 - 04:26 AM |
