Porsche 6 speed tranny with a porsche 6 cyl engine, Anyone ever try adapting a 6 speed porsche tranny (1995-1996) for mid |
Dinobx |
Apr 22 2006, 02:35 PM
Newbie Group: Members Posts: 44 Joined: 15-August 05 From: Toronto, Ontario Member No.: 4,592 |
Anyone ever try converting the 1995-1996 year 6 speed porsche tranny's for mid engine use? For that matter, would it be easier if you were also installing the engine that was originally mated to that tranny, a 3.6?
Ideas, thoughts? Dino |
Jeroen |
Apr 23 2006, 06:56 AM
On the G50 (derived) gearboxes you can't flip the diff, so you'll have to mount the box upside down. Not really a problem, quite a few have done so...
But IIRC, the 6 speed gearboxes are too long to fit in a 914 |
LvSteveH |
Apr 23 2006, 10:57 AM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
On the G50 (derived) gearboxes you can't flip the diff, so you'll have to mount the box upside down. Not really a problem, quite a few have done so... But IIRC, the 6 speed gearboxes are too long to fit in a 914 The 5 speed G50 is already pretty long, so the 6 would be pushing it. I read somewhere that the G50 was actually initially designed to run inverted in a race car prior to being flipped over for production use. Either way, they seem to be very happy in a mid engine application. |
Dinobx |
Apr 23 2006, 06:56 PM
On the G50 (derived) gearboxes you can't flip the diff, so you'll have to mount the box upside down. Not really a problem, quite a few have done so... But IIRC, the 6 speed gearboxes are too long to fit in a 914 The 5 speed G50 is already pretty long, so the 6 would be pushing it. I read somewhere that the G50 was actually initially designed to run inverted in a race car prior to being flipped over for production use. Either way, they seem to be very happy in a mid engine application. Yeah, my problem is that in looking to convert to a 3.6 engine, the gearing of the 901 just isn't right. Another option I'm looking at is changing all of the gears so that the ratios are better matched for a higher torque engine. Dino |
alpha434 |
Apr 23 2006, 07:39 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Look up specs for the "Moby Dick" group 5 Martini car. They used a flipped trans to allow for MASSIVE wheels and a mid mounted engine in a 935 chassis. There were a few others in the same time period that did the same, but many of them turned out to have "diabloical" handling traits.
My idea: refab the rear suspension an elongate the body a little to accomodate the larger trans/engine combo. Best of luck. |
Aaron Cox |
Apr 23 2006, 07:45 PM
On the G50 (derived) gearboxes you can't flip the diff, so you'll have to mount the box upside down. Not really a problem, quite a few have done so... But IIRC, the 6 speed gearboxes are too long to fit in a 914 The 5 speed G50 is already pretty long, so the 6 would be pushing it. I read somewhere that the G50 was actually initially designed to run inverted in a race car prior to being flipped over for production use. Either way, they seem to be very happy in a mid engine application. Yeah, my problem is that in looking to convert to a 3.6 engine, the gearing of the 901 just isn't right. Another option I'm looking at is changing all of the gears so that the ratios are better matched for a higher torque engine. Dino wasnt mid engine i dont think..... (IMG:http://i.pbase.com/o4/65/621265/1/58705951.58649181.30paddock3.jpg) |
Aaron Cox |
Apr 23 2006, 07:46 PM
Brando |
Apr 23 2006, 08:08 PM
Is that a wheelie bar? lol
Lo-Fi Version | Time is now: 17th May 2024 - 05:45 PM |
