tops ou at 4000 rpm |
nycchef |
Apr 22 2006, 07:45 PM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
have 73 1.7 engines revs up to 4000rpm and seems and stays there. if i ease off the gas and then go back it goes away mostly in 1st and 2nd gear. any thoughts? i am as lost as my mechanic thanks rich
bd1308 |
Apr 22 2006, 08:38 PM
same thing happened on my car, and I found out that the timing was WAY too advanced.
b |
Joe Bob |
Apr 22 2006, 08:43 PM
My first ride had a crappy Anza exhaust.....it was WAY too restrictive and was clogged with rust and other crud. I replaced it with a Bursch....worked a lot better. It was still a slow as molassess 1.7 but it revved to 6K....
Aaron Cox |
Apr 22 2006, 08:44 PM
does the centrif. advance work in the dizzy? timed right?
what induction system? carbs or efi? |
DanT |
Apr 22 2006, 08:57 PM
Check your EFI trigger points. My 2.0L had the same symptoms and the trigger points took care of it. (IMG:style_emoticons/default/biggrin.gif)
nycchef |
Apr 23 2006, 05:40 AM
nycchef |
Apr 23 2006, 05:42 AM
nycchef |
nycchef |
Apr 23 2006, 05:44 AM
Check your EFI trigger points. My 2.0L had the same symptoms and the trigger points took care of it. (IMG:style_emoticons/default/biggrin.gif) will try you guys are great in case noone noticed i type like s--t |
bd1308 |
Apr 23 2006, 06:03 AM
I do two.
So.Cal.914 |
Apr 23 2006, 04:53 PM
does the centrif. advance work in the dizzy? timed right? what induction system? carbs or efi? efi what is a dizzy? thanks for the input Electronic Fuel Injection = EFI Dizzy = Distributor (IMG:style_emoticons/default/smoke.gif) |
davep |
Apr 23 2006, 06:23 PM
Check compression and/or leakdown.
Lo-Fi Version | Time is now: 17th May 2024 - 08:01 PM |
