nycchef
Apr 22 2006, 07:45 PM
have 73 1.7 engines revs up to 4000rpm and seems and stays there. if i ease off the gas and then go back it goes away mostly in 1st and 2nd gear. any thoughts? i am as lost as my mechanic thanks rich
bd1308
Apr 22 2006, 08:38 PM
same thing happened on my car, and I found out that the timing was WAY too advanced.
b
Joe Bob
Apr 22 2006, 08:43 PM
My first ride had a crappy Anza exhaust.....it was WAY too restrictive and was clogged with rust and other crud. I replaced it with a Bursch....worked a lot better. It was still a slow as molassess 1.7 but it revved to 6K....
Aaron Cox
Apr 22 2006, 08:44 PM
does the centrif. advance work in the dizzy? timed right?
what induction system? carbs or efi?
DanT
Apr 22 2006, 08:57 PM
Check your EFI trigger points. My 2.0L had the same symptoms and the trigger points took care of it.
nycchef
Apr 23 2006, 05:40 AM
QUOTE(Aaron Cox @ Apr 22 2006, 06:44 PM)
efi what is a dizzy? thanks for the input
nycchef
Apr 23 2006, 05:42 AM
QUOTE(bd1308 @ Apr 22 2006, 06:38 PM)
b
thanks for the replay will pass along to einstien the mechanic
nycchef
QUOTE((*)(*) @ Apr 22 2006, 06:43 PM)
exhaust is new thnks for the help
nycchef
Apr 23 2006, 05:44 AM
QUOTE(Dan (Almaden Valley) @ Apr 22 2006, 06:57 PM)
will try you guys are great in case noone noticed i type like s--t
bd1308
Apr 23 2006, 06:03 AM
I do two.
So.Cal.914
Apr 23 2006, 04:53 PM
QUOTE(nycchef @ Apr 23 2006, 04:40 AM)
Electronic Fuel Injection = EFI
Dizzy = Distributor
davep
Apr 23 2006, 06:23 PM
Check compression and/or leakdown.
