Need to repair rusty part, Point me in the right direction |
dralf |
Apr 25 2006, 02:23 PM
Member Group: Members Posts: 230 Joined: 24-January 04 From: Dayton, Oh Member No.: 1,597 |
Perhaps one of you can point me in the right direction. I have a rusted DRIVERS side rear trailing arm suspension point. I have enclosed a pic of the triangle thing that needs replaced. The passenger side one was done some time ago by the PO. The body shop where I took it (Euro Classics – Dayton Ohio) indicated that perhaps the Dog Ears portion of this was also bad and should be replaced while he was at it.
I started to look for rust repair parts and can’t seem to find the parts I need. Perhaps the real technical names would help me locate these parts or can someone offer some help and warning as what to watch out for. I will post some pictures of my car and its situation in the next few days. (IMG:style_emoticons/default/sad.gif) Attached image(s) |
Part Pricer |
Apr 25 2006, 02:39 PM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
Take a look on the Restoration Design site http://restoration-design.com/ They should have what you need. |
balljoint |
Apr 25 2006, 03:03 PM
I think the only repair piece for the inside mount is for the passenger side, and I don't know if you can flip it around and use it, as it is not a symmetrical piece. Your best bet is a donor car. (IMG:style_emoticons/default/stan.gif)
Oh and as I actually look at your picture I see it is the outer mounting point that you need. Start looking for a donor.... |
grasshopper |
Apr 25 2006, 05:57 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
yep, you cant buy that piece. I have a donor car with a good drivers side one, but it might take a couple weeks to get it out...if you are interested... just be ready to find more rust underneath of it.... I have to replace the passenger side on my car, but I was able to put my hand IN it, and pull it off...yeah.. (IMG:style_emoticons/default/smile.gif)
jonwatts |
Apr 25 2006, 09:30 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
I have that part! Let me take a picture and post it here. Check back in about 10 minutes...
thx, Jon |
jonwatts |
Apr 25 2006, 10:01 PM
Here you go, let me know if you think this will work for you.
Jon |
dralf |
Apr 26 2006, 09:45 AM
(IMG:style_emoticons/default/smile.gif) Jon I PMed you today for it looks like you have what I need.
Grasshopper, thanks for your response and I may need to take you up on your offer if once they start cutting and welding there is lots more rust. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:07 PM |
