splitting case, why wont it come apart? |
shaggy |
Apr 26 2006, 06:33 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
i have a dirty 2.0l case that wont come apart
im doing an entire rebuild and need the case opened to see what cam i have and for cleaning there is some black stuff in the seams it kinda lookes cracked but its not moving i was holding it by studs and had my brother pulling down ward as i had a friend hitting the seam with a rubber mallet and got no movement from a said rail guy i heard use a propane tourch w/ a wide flame to loosen it up while pulling any ideas? -shag |
Joe Bob |
Apr 26 2006, 06:37 PM
Keep looking....ya missed a nut.
type11969 |
Apr 26 2006, 06:40 PM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
make sure you've undone every bolt, even one will stop it from budging. There are some bolts in odd places that can get easily covered in gunk . . . under the crank where the flywheel joins it, under the crank where the pulley joins it, on the bottom of the case hidden amongst the fins, and of course the one hidden between the lifter bores on the oil cooler side.
shaggy |
sure i didnt
ive had 5 different people look it all over when it was on my stand and everyone has said they are all out -shag |
type11969 |
Apr 26 2006, 06:43 PM
Hmm, does look like that engine has been rebuilt judging by the epoxy over the galley plugs and the brown goo along the seam . . . looks like it might be permatex 3H which cleans up pretty well with acetone. Try some acetone along the seams to see if it loosens the goo up, it might help.
Mueller |
Apr 26 2006, 06:47 PM
sure i didnt ive had 5 different people look it all over when it was on my stand and everyone has said they are all out -shag you need a block of wood and a couple of (IMG:style_emoticons/default/smash.gif) |
shaggy |
Apr 26 2006, 06:48 PM
acetone huh?
ill have to try that tonight cuz all the bolts you listed i can bemember taking out the ones under the flywheel and pump i had to use a u-joint thing for thank -shag |
Joe Bob |
Apr 26 2006, 06:58 PM
There's one or two that require a DEEP SOCKET and you can't really see and are accessed via long extension....if I remember....been awhile since I tore down a T-4.
Jake Raby |
Apr 26 2006, 07:00 PM
If the engine does not split super easily you have a nut left in place.... Do you have my video, I go over EVERY nut because tons of cases are ruined because of ONE nut!
bd1308 |
Apr 26 2006, 07:02 PM
NO SCREWDRIVERS
NO NO NO b |
McMark |
Apr 26 2006, 07:20 PM
Try the acetone, but you missed a nut. Notice a trend here? (IMG:style_emoticons/default/wink.gif)
shaggy |
Apr 26 2006, 07:28 PM
hahahahaha
ya i am noticing that ill go look soon... -shag |
McMark |
Apr 26 2006, 07:30 PM
Is your oil pickup loose in the case? If the pickup doesn't wiggle around that's the bolt you missed. It's very deep in the case and very very easy to miss since it's usually completely covered in sludge.
shaggy |
Apr 26 2006, 07:34 PM
"Is your oil pickup loose in the case?"
ya...i dont know that that is... care to explain? -shag |
jd74914 |
Apr 26 2006, 07:41 PM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
My engine had all of the nuts removed and wouldn't budge. I needed to use the hammer and a block to get it open. It didn't split very easily at all. It took me a long time to get it open.
McMark |
Apr 26 2006, 07:45 PM
Once you've removed the large round cover on the bottom of the case there is a tube which is where your oil gets sucked up by the pump. That tube should be very loose in the case. If it feels "attached" it probably is and there's your last bolt.
shaggy |
Apr 26 2006, 08:33 PM
the oil pick up is loose in the case
it moves freely in all dirrections i can hear/ feel the crank moving too is that means anything on the driver side of the case(i dont know what cylinder #s corespond to what side) there is a giant triple square bolt does that have to come out? other than that there are no bolts missed im sure of it id use the acetone but my mommy isnt here to give me her nail polish remover and i dont have a sister... (IMG:style_emoticons/default/dry.gif) so i guess im out to dinner and will stop and pick some up -shag p.s. there tons of rtv on the flywheel side of the case the main seal is rtved in and the flat spots have rtv on them and it was placed there it isnt excess idk if this shows them at all but its a try |
John |
Apr 26 2006, 08:50 PM
Um,
You do have the OIL PUMP off, don't you? I just thought I would start asking the obvious first and then narrow it down.... When did Mr Raby get back? |
bryanc |
Apr 26 2006, 08:52 PM
Member Group: Members Posts: 321 Joined: 9-August 04 From: San Antonio, Tx Member No.: 2,495 Region Association: Southwest Region |
The triple square is the oil pressure relief spring, not related holding the case together.
Jake Raby |
Apr 26 2006, 08:55 PM
QUOTE When did Mr Raby get back? He is not back yet.... Just working on my new site and pulling my hair out waiting for the changes to upload! |
Lo-Fi Version | Time is now: 11th June 2024 - 07:48 AM |
