PAIN IN THE!>......, sticky car |
BMXerror |
Apr 29 2006, 05:27 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Hey guys. I'm still trying to unstick all the stuck stuff on my teener that's been sitting for way too long. I've got everything except the front trunk. I know the cable's attached and everything. I think the latch is just seized up and I can't get to it from any other angle. Anyone got any suggestions on how to solve this. Feel free to include major disassembly, because I think that may be necessary. (IMG:style_emoticons/default/sawzall-smiley.gif)
Mark D. |
rhodyguy |
Apr 29 2006, 05:32 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
are you saying you can't open the front trunk? or just a sticky cable?
k |
gopack |
Apr 29 2006, 05:44 PM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
All you need to do is take off the front bumper, (four bolts in the wheel wells, 2 on each side) and there is a nice hole that the factory provided that will let you release the trunk latch with a screwdriver.
rhodyguy |
Apr 29 2006, 05:52 PM
i had a latch problem at the wcc05. after i had removed the bumper i discovered someone had previously drilled a hole in the bumper in exactly the right spot. look behind the license plate before you pull the bumper.
k |
BMXerror |
Apr 29 2006, 06:06 PM
There is no front licence plate, so no luck there. However, taking the bumper off is less work than I was prepared for. Thanks guys. I couldn't get into the rear either because someone converted it to a servo activated latch and the battery was dead. I couldn't change the battery because the engine lid latch was frozen up. I had to figure out how the latch worked by staring through the crack between the trunk and the engine lid for about an hour, and then minipulate it with a bent screwdriver. I was victorious. (IMG:style_emoticons/default/piratenanner.gif) Thanks again.
Mark D. |
Lo-Fi Version | Time is now: 28th May 2024 - 06:00 PM |
