Interesting comparisons, In case you wanted to know |
914Sixer |
Apr 29 2006, 07:50 PM
914 Guru Group: Members Posts: 8,896 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Brian Mifsud |
Apr 29 2006, 10:30 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
aside from the difference in shinyness, isn't the only difference the 1/4" spacer sitting between the halves?
newto914s |
Apr 29 2006, 11:37 PM
Senior Member Group: Members Posts: 561 Joined: 16-February 04 From: Thornton, CO Member No.: 1,663 |
Good eye Brian,
if that's true, would it be possible to machine a spacer to mod stock brakes to fit vented rotors? |
Brando |
Apr 29 2006, 11:59 PM
I believe someone offers that kit already here on the club board.
Only issue I can imagine is the little rubber seals (o-rings?) that are NLA. |
McMark |
Apr 30 2006, 12:49 AM
The pistons on the six caliper are MUCH larger.
But yes you can put spacers into a four calipers. Search, my friend. Discussed a lot already, it has been. (IMG:style_emoticons/default/yoda.gif) |
John |
Apr 30 2006, 02:38 AM
The pad size on the /6 caliper is larger as well. I believe it is the same size as a 914-4 front pad. (same size as a 911 SC rear pad)
Spacing out the 4-cyl rear calipers doesn't give that good of results. To use vented rotors with spaced out 4-cyl calipers, the rotors must be turned down approx 4mm in diameter to even fit. Then, you are still stuck with the small pistons and pads from the 4-cyl calipers. Then you must find 7mm hardware long enough for the spaced calipers. You must also find/fabricate pins long enough and last but not least, you have to make/adapt spreader springs for the spaced 4-cyl calipers. From what I understand, the spacers from 911 rear calipers and all the 911 rear caliper hardware will swap directly into the 914/6 calipers. However, I have noticed that 914/6 rear caliper rebuild kits are listed as being NLA at several parts houses. The advantage is that you probably already have them and that you can keep the stock e-brake. You could adapt 911 e-brakes and use 911 rear calipers. (which is what I decided to do) just my $0.02 |
davep |
Apr 30 2006, 06:41 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
aside from the difference in shinyness, isn't the only difference the 1/4" spacer sitting between the halves? You should be able to see that the 914/6 caliper is much wider than the 914/4 caliper. Bigger pistons, bigger pads, different everything. BTW, the spacer should be 10mm. |
Lo-Fi Version | Time is now: 29th May 2024 - 08:47 PM |
