QUOTE(Brian Mifsud @ Apr 29 2006, 08:30 PM)
aside from the difference in shinyness, isn't the only difference the 1/4" spacer sitting between the halves?
You should be able to see that the 914/6 caliper is much wider than the 914/4 caliper. Bigger pistons, bigger pads, different everything. BTW, the spacer should be 10mm.
