Intake Manifold to Heads mating surface, How do i know its sealing? |
yarin |
May 1 2006, 05:18 AM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I'm not 100% certain that the mating surface between the intake runners and heads are leak free. I used the gaskets (what material is that) and torqued down the bolts. Can I use a high temp sealant on both sides of the gasket? All of the injector rings are new, can I assume there are no leaks there?
I sprayed the top of the manifold/runners with carb cleaner and didnt notice a chance in RPM. What would i expect to see? Thanks |
Lo-Fi Version | Time is now: 28th May 2024 - 10:45 AM |
