I'm not 100% certain that the mating surface between the intake runners and heads are leak free. I used the gaskets (what material is that) and torqued down the bolts. Can I use a high temp sealant on both sides of the gasket? All of the injector rings are new, can I assume there are no leaks there?
I sprayed the top of the manifold/runners with carb cleaner and didnt notice a chance in RPM. What would i expect to see?
Thanks
