Aftermarket Fuel Pump, Mallory seems to be the choice but a few ? |
tdgray |
May 1 2006, 07:55 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
So from doing a search it seems that the Mallory 4060fi is the prefered pump for aftermarket replacement. Just a few questions though.
Do I have to move the pump to the front if I use this one? If I move it to the front where should I put it. Logic says right under the tank. For those that have relocated it. What did you do about wiring? Run wires inside cockpit or what. Should I put in dual filters. One before the pump and then one after. Thanks as usual. |
rhodyguy |
May 1 2006, 08:00 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
filter before the pump to keep the crap out of it.
k |
tdgray |
May 1 2006, 09:04 AM
Yepper... what about everything else.
Bueller...Bueller...Bueller |
tdgray |
May 1 2006, 12:50 PM
(IMG:style_emoticons/default/icon_bump.gif) for the left coasters opinions
I want to go get this thing after work (yes Summit Racing is right around the corner from me... anybody need anything (IMG:style_emoticons/default/biggrin.gif) ) Need opinions before then. Thanks. |
Mueller |
May 1 2006, 01:02 PM
from what I've read....fuel pumps are better "pushers" than "suckers", so mounted up front near the tank is best....
mine is currently mounted in the front trunk (I have the MSD pump which Jake hates (IMG:style_emoticons/default/smile.gif) ) ...it looks very close to the '75/'76 stock pump.... 2 filters, one pre-pump and one post pump.... according to James M, the closer the power source relay and fuse to the component the better... |
2-OH! |
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Todd:
Do you use FI or Carbs.... 2-OH! |
tdgray |
May 1 2006, 01:35 PM
Standard 1.7 FI engine- totally stock.
Thanks M... thats what I was thinking...I just hate to get involved in moving everything. I got a nice mount back there and I cut all the lines for teh stock unit. Oh well such is life (IMG:style_emoticons/default/sad2.gif) |
Lo-Fi Version | Time is now: 28th May 2024 - 05:57 PM |
