So from doing a search it seems that the Mallory 4060fi is the prefered pump for aftermarket replacement. Just a few questions though.
Do I have to move the pump to the front if I use this one?
If I move it to the front where should I put it. Logic says right under the tank.
For those that have relocated it. What did you do about wiring? Run wires inside cockpit or what.
Should I put in dual filters. One before the pump and then one after.
Thanks as usual.
