triad install question, how much of my backend do I need to cut out? |
Aaron Cox |
May 2 2006, 09:44 PM
you won the battle little dude.... but you lost the war (IMG:style_emoticons/default/tongue.gif) (IMG:style_emoticons/default/chairfall.gif) |
DanT |
May 2 2006, 09:47 PM
war?? did I miss something? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/confused24.gif)
And who says I am little? |
Aaron Cox |
May 2 2006, 09:48 PM
war?? did I miss something? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/confused24.gif) And who says I am little? just a stupid quote from home alone.... lol. dan. "why cant we be friends, why cant we be friends" (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/drunk.gif) |
DanT |
May 2 2006, 09:50 PM
No problem....just dishing a little bit out, instead of taking it for a change (IMG:style_emoticons/default/biggrin.gif)
stephen7 |
May 2 2006, 10:02 PM
Member Group: Members Posts: 69 Joined: 4-March 06 From: seattle wa Member No.: 5,663 |
No problem....just dishing a little bit out, instead of taking it for a change (IMG:style_emoticons/default/biggrin.gif) So - waduyouthink? Just find some heat exchangers that are straight? I don't have any heat in this car by the way. Does that matter? It is strictly an autocrosser merci bien steve |
DanT |
May 2 2006, 10:05 PM
either you find a set of 2.0L SSIs or stock heat exchangers. Or you get yourself a muffler that works with 1.7L heat exchangers. Or get rid of it all and get some headers. What you have heat exchanger wise will not work with your Triad.
stephen7 |
May 2 2006, 10:09 PM
either you find a set of 2.0L SSIs or stock heat exchangers. Or you get yourself a muffler that works with 1.7L heat exchangers. Or get rid of it all and get some headers. What you have heat exchanger wise will not work with your Triad. Thanks guys - you saved me a lot of agony |
Gint |
May 2 2006, 10:13 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
No problem....just dishing a little bit out, instead of taking it for a change (IMG:style_emoticons/default/biggrin.gif) So - waduyouthink? Just find some heat exchangers that are straight? I don't have any heat in this car by the way. Does that matter? It is strictly an autocrosser merci bien steve I'd buy a header if I didn't want heat. You could keep those HE's and have Dave at Triad modify them if you ever want to go back to heat. |
swood |
May 2 2006, 11:59 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Dude, you drew dual dongs on that ass end...wassup widat?? (IMG:style_emoticons/default/bootyshake.gif) |
jasons |
May 3 2006, 12:10 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
stephen7 |
May 3 2006, 02:55 AM
maybe - what is it worth to you? I heard I could get a used header for around $250. How do the triads sound? I am driving without any muffler right now and it sounds like I am driving a cessna 172 with the pitch turned all the way up and throttle all the way open. (Sounds tough) steve
type47 |
May 3 2006, 05:42 AM
i think you should verify that you have a bus engine, not that it makes a huge amount of difference with your exhaust situation. for future work and parts purchase, you would want to know. my bet is you have a 1.7L 914, not "bus" but the person who told you this may just have been referring to the motor as the same engine as is in the bus, since it "basically" is the same.
jasons |
May 3 2006, 07:34 AM
maybe - what is it worth to you? I heard I could get a used header for around $250. How do the triads sound? I am driving without any muffler right now and it sounds like I am driving a cessna 172 with the pitch turned all the way up and throttle all the way open. (Sounds tough) steve Whats the story on it? Condition etc.... I'll open an offer at $175 |
Lo-Fi Version | Time is now: 9th June 2024 - 05:16 AM |
