Porsche 901 Trans and VW Trans question, Is the bolt pattern / clutch assy depth the same? |
flyloki |
May 3 2006, 11:07 AM
Member Group: Members Posts: 138 Joined: 20-October 03 From: 8:00 in Boise, Idaho Member No.: 1,264 |
Could a Type 1 VW motor bolt right up to a 901 with no adapter?
Aaron Cox |
May 3 2006, 11:08 AM
flyloki |
May 3 2006, 11:16 AM
Any reason for the diff flywheel? Application is an electric motor adapter plate that is designed for type 1 trannys. |
Aaron Cox |
May 3 2006, 11:18 AM
i know the 4 bolts from case to tanny are in the same points.....
whats the OD of a vw flywheel? 914? not sure what is required on the clutch side of things |
Lo-Fi Version | Time is now: 25th May 2024 - 01:56 PM |
