Help
Search
Members
Calendar
Full Version:
Porsche 901 Trans and VW Trans question
914World.com
The 914 Forums
914World Garage
flyloki
May 3 2006, 11:07 AM
Could a Type 1 VW motor bolt right up to a 901 with no adapter?
Aaron Cox
May 3 2006, 11:08 AM
yup
you may need a special flywheel tho....
brain fart
flyloki
May 3 2006, 11:16 AM
QUOTE(Aaron Cox @ May 3 2006, 09:08 AM)
yup
brain fart
Any reason for the diff flywheel? Application is an electric motor adapter plate that is designed for type 1 trannys.
Aaron Cox
May 3 2006, 11:18 AM
i know the 4 bolts from case to tanny are in the same points.....
whats the OD of a vw flywheel? 914?
not sure what is required on the clutch side of things
click here
Invision Power Board © 2001-2024
Invision Power Services, Inc.
