Anybody ever seen a 901 tranny do this before?, broken parts--bad month for transmissions |
bryanc |
May 4 2006, 02:10 AM
Member Group: Members Posts: 321 Joined: 9-August 04 From: San Antonio, Tx Member No.: 2,495 Region Association: Southwest Region |
More transmission troubles occurred for me a couple of weekends ago....
A different transmission from this one, but same car.... I downshifted into 2nd for a corner, felt weird, but got it in gear, then third, then downshift for a chicane. kablamo! Took it apart tonight and found.... case is cracked, top, side and bottom.... |
rick 918-S |
May 4 2006, 07:21 AM
Hey nice rack! -Celette Group: Members Posts: 20,457 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Don't think you'll buff that one out...
brant |
May 4 2006, 08:43 AM
oh crap...
I'm sorry Bryan |
john rogers |
May 4 2006, 09:07 AM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
What engine do you run? There were several failures of the R&P and such when HSR WEst started the 2L vintage series and the engines were revving pretty high. This was cured by using a lube pump and cooler and in the last several years I haven't heard of any?
brant |
May 4 2006, 09:09 AM
What engine do you run? There were several failures of the R&P and such when HSR WEst started the 2L vintage series and the engines were revving pretty high. This was cured by using a lube pump and cooler and in the last several years I haven't heard of any? my recollection (knew the seller) Its a PCA GT-5 engine built with GE80's I believe and likely around 220hp. |
gregrobbins |
May 4 2006, 09:31 AM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
No problems Bryan, a little JP Weld and you will be good to go. (IMG:style_emoticons/default/biggrin.gif)
John |
May 4 2006, 11:15 AM
'Tis just a scratch....
Shouldn't that be covered under warranty? (IMG:style_emoticons/default/av-943.gif) |
LvSteveH |
May 4 2006, 12:07 PM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
Shift Smooooooooother (IMG:style_emoticons/default/wink.gif)
Aaron Cox |
May 4 2006, 12:10 PM
CaRnAgE (IMG:style_emoticons/default/chowtime.gif)
bryanc |
May 4 2006, 02:14 PM
What engine do you run? There were several failures of the R&P and such when HSR WEst started the 2L vintage series and the engines were revving pretty high. This was cured by using a lube pump and cooler and in the last several years I haven't heard of any? It wasn't a R&P failure, but I think the rebuild is going to include a tranny cooler. Who makes those? |
bryanc |
May 4 2006, 02:16 PM
That's the goal. I've been having "issues" with my heel-toe technique. The engine drops revs so fast that it's really somewhat pointless. The 'flywheel' is ultralight and the car has a tilton clutch with almost no mass--fast, but not smooth. |
Aaron Cox |
May 4 2006, 02:17 PM
What engine do you run? There were several failures of the R&P and such when HSR WEst started the 2L vintage series and the engines were revving pretty high. This was cured by using a lube pump and cooler and in the last several years I haven't heard of any? It wasn't a R&P failure, but I think the rebuild is going to include a tranny cooler. Who makes those? MoCaL makes a tranny pump as seen at racerpartswholesale.com. (electric) |
Lo-Fi Version | Time is now: 15th May 2024 - 04:31 AM |
