Relay Boards, can they be rebuilt? |
STL914 |
May 4 2006, 07:38 AM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
I have a couple of relay boards from my parts cars that I would like to have refurbished.
I seem to recall that a club member at one time offered this service but I am unable to find any reference to this on the club web site. Can someone point me in the right direction or have experience having theirs refurbished; either doing it themselves or by a vendor? Is it difficult to do at home? Tanx (IMG:style_emoticons/default/biggrin.gif) |
914Sixer |
May 4 2006, 08:07 AM
They are easy to redo. You will have to soak the board in a cleaner and remove the tar on the bottom. Then take a volt/ohm meter and test the connections. Diagrams are in any repair manual. You can then take one of the new instant soldier gun and soldier the rivets to the copper strips. Last step with be to put a coating on the bottom that are available at Radio Shack.
StratPlayer |
May 4 2006, 09:54 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I went through this process, cleaned out the old crap on the bottom of the board, checked all the circuits the I coated the bottom of the board with liquid electricial tape. You can get the liquid tape at any Home Depot great stuff and works very well.
STL914 |
May 4 2006, 04:22 PM
They are easy to redo. You will have to soak the board in a cleaner and remove the tar on the bottom. Then take a volt/ohm meter and test the connections. Diagrams are in any repair manual. You can then take one of the new instant soldier gun and soldier the rivets to the copper strips. Last step with be to put a coating on the bottom that are available at Radio Shack. Do you happen to know the name of the cleaner you used? |
StratPlayer |
May 4 2006, 04:33 PM
Hope this helps you out
http://www.914world.com/bbs2/index.php?showtopic=4940&st=20 |
Lo-Fi Version | Time is now: 14th May 2024 - 09:02 AM |
