probably a dumb tire question, can they get "out of round"? |
JerryP |
May 4 2006, 01:22 PM
member Group: Members Posts: 314 Joined: 8-October 03 From: Berwyn, PA Member No.: 1,225 |
I put rims/tires on my 72 914 that I had on another 914. The treads appear to be fine and I can't find any dry rot but the tires sat on the other 914 for a long time, like a few years...at between 10-20 psi. I can't see anything odd visually but I can definitely feel a bumpier ride especially at slow speeds, which I did not have with my other rims/tires. It seems like its coming from the front passenger side tire.
Can a tire actually get out of round? Could it be that they just need to be balanced? It's a bent rim isn't it? (IMG:style_emoticons/default/dry.gif) |
Aaron Cox |
May 4 2006, 01:24 PM
balance?
Bent rim? tires can "flatspot" from sitting too long |
tdgray |
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Yes a tire can get out of round... usually temporarily. Happens to my MGA avery winter. A little driving and they are right back where they should be.
My bet is a bent rim. |
highways |
May 4 2006, 01:26 PM
Senior Member Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 |
Steel belt radial inside the tire is probably shot. Yes they get out of round, from exactly the condition you described. I'm going to have the same problem. They're junk now. They'll do damage to your ball joints, suspension, and who knows what else.
highways |
May 4 2006, 01:28 PM
Well, maybe someone else knows better then me. I thought they would be junk, maybe not. But I wouldn't want to 'use my car' to 'round them out again'.
JerryP |
May 4 2006, 01:42 PM
[quote name='tdgray' date='May 4 2006, 03:24 PM' post='675300']
Yes a tire can get out of round... usually temporarily. Happens to my MGA avery winter. A little driving and they are right back where they should be. Nice, I'm not totally insane. How much driving are we talking about. I've probably gone 40 or 50 miles. 0-30mph noticeable......30-60 less so.....above 60....steering wheel shakes a little. I was hoping not to have to shell out for new tires just yet but I don't want to put my suspension at risk. |
JerryP |
May 4 2006, 01:57 PM
Tires are Vredestein Sprint Classics 185/70. I never heard of them before. Anyone know anything about them? They still sell them at $128/each.
tdgray |
May 4 2006, 02:03 PM
Not really sure how long it takes. Maybe a trip to and from work... about 40 miles.
I would take them to a reputable tire place and have them checked. They will be able to tell you right away if the rims is bent or they need balanced. Not very expensive. |
JerryP |
May 4 2006, 02:06 PM
agreed. Thanks. That's what I'll be doing.
Crazyhippy |
May 4 2006, 07:27 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
Get a lil heat in them... every tire that i've had flat spot from sitting came back in 30 miles or less, on the freeway.
Had bias ply tires on a jeep and they would flat spot nightly... :-( BJH |
Lo-Fi Version | Time is now: 15th May 2024 - 10:21 AM |
