JerryP
May 4 2006, 01:22 PM
I put rims/tires on my 72 914 that I had on another 914. The treads appear to be fine and I can't find any dry rot but the tires sat on the other 914 for a long time, like a few years...at between 10-20 psi. I can't see anything odd visually but I can definitely feel a bumpier ride especially at slow speeds, which I did not have with my other rims/tires. It seems like its coming from the front passenger side tire.
Can a tire actually get out of round?
Could it be that they just need to be balanced?
It's a bent rim isn't it?
Aaron Cox
May 4 2006, 01:24 PM
balance?
Bent rim?
tires can "flatspot" from sitting too long
tdgray
Yes a tire can get out of round... usually temporarily. Happens to my MGA avery winter. A little driving and they are right back where they should be.
My bet is a bent rim.
highways
May 4 2006, 01:26 PM
Steel belt radial inside the tire is probably shot. Yes they get out of round, from exactly the condition you described. I'm going to have the same problem. They're junk now. They'll do damage to your ball joints, suspension, and who knows what else.
highways
May 4 2006, 01:28 PM
Well, maybe someone else knows better then me. I thought they would be junk, maybe not. But I wouldn't want to 'use my car' to 'round them out again'.
JerryP
May 4 2006, 01:42 PM
[quote name='tdgray' date='May 4 2006, 03:24 PM' post='675300']
Nice, I'm not totally insane. How much driving are we talking about. I've probably gone 40 or 50 miles. 0-30mph noticeable......30-60 less so.....above 60....steering wheel shakes a little. I was hoping not to have to shell out for new tires just yet but I don't want to put my suspension at risk.
JerryP
May 4 2006, 01:57 PM
Tires are Vredestein Sprint Classics 185/70. I never heard of them before. Anyone know anything about them? They still sell them at $128/each.
tdgray
May 4 2006, 02:03 PM
Not really sure how long it takes. Maybe a trip to and from work... about 40 miles.
I would take them to a reputable tire place and have them checked. They will be able to tell you right away if the rims is bent or they need balanced.
Not very expensive.
JerryP
May 4 2006, 02:06 PM
agreed. Thanks. That's what I'll be doing.
Crazyhippy
May 4 2006, 07:27 PM
Get a lil heat in them... every tire that i've had flat spot from sitting came back in 30 miles or less, on the freeway.
Had bias ply tires on a jeep and they would flat spot nightly... :-(
BJH
