Taco Plate, What is it's tech name or part# |
johnmhudson111 |
May 4 2006, 04:14 PM
Member Group: Members Posts: 491 Joined: 29-November 04 From: Nesbit, MS Member No.: 3,191 |
Trying to find one to replace the leaking one on the 1.8. Needs to be the one made for the oil temp sender. Mine wasn't and when drilled I bent it and now it leaks......
Anyway, any help would be great..... |
JoeSharp |
May 4 2006, 04:31 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
How is the fusch do you spell acornim? T.A.C.O. stands for something. Do a search.
:PERMAGRIN: Joe |
StratPlayer |
May 4 2006, 04:34 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I know Jake Raby has some used ones for sale at his type 4 store
http://www.aircooledtechnology.com/store/home.php |
Cap'n Krusty |
May 4 2006, 04:38 PM
039 101 267, according to the package for the NEW one I have here. About 70 bucks ....................... The Cap'n
Aaron Cox |
May 4 2006, 04:39 PM
How is the fusch do you spell acornim? T.A.C.O. stands for something. Do a search. :PERMAGRIN: Joe "Acronym" (IMG:style_emoticons/default/smile.gif) and i think it is affectionately called a taco plate because it "taco's" when you over tighten the 2 bolts.... and after it taco's it leaks... no one likes leaky taco's (IMG:style_emoticons/default/smile.gif) |
SLITS |
May 4 2006, 04:49 PM
039 101 267 - cover for temperature sensor for oil sump
021 101 269 A - sealing ring for cover 039 101 287 - gasket for temperature sensor 039 101 275 - protection cap temperature sensor cover oil sump 039 101 203 - cable holder temperature sensor N 013 803 2 - sealing ring for hexhead bolt N 010 210 13 - bolt hexhead M6X10 K That's about all the parts that comprise the T.A.C.O plate assembly. Been into the Cassadores a little early there Joe? |
SLITS |
May 4 2006, 04:51 PM
How is the fusch do you spell acornim? T.A.C.O. stands for something. Do a search. :PERMAGRIN: Joe "Acronym" (IMG:style_emoticons/default/smile.gif) and i think it is affectionately called a taco plate because it "taco's" when you over tighten the 2 bolts.... and after it taco's it leaks... no one likes leaky taco's (IMG:style_emoticons/default/smile.gif) Been "South of the Border" dating again Aaron? |
type47 |
May 4 2006, 05:27 PM
cover for telethermometer?
Lo-Fi Version | Time is now: 15th May 2024 - 09:27 PM |
