Trying to find one to replace the leaking one on the 1.8. Needs to be the one made for the oil temp sender. Mine wasn't and when drilled I bent it and now it leaks......
Anyway, any help would be great.....
JoeSharp
May 4 2006, 04:31 PM
How is the fusch do you spell acornim? T.A.C.O. stands for something. Do a search. :PERMAGRIN: Joe
StratPlayer
May 4 2006, 04:34 PM
I know Jake Raby has some used ones for sale at his type 4 store
039 101 267, according to the package for the NEW one I have here. About 70 bucks ....................... The Cap'n
Aaron Cox
May 4 2006, 04:39 PM
QUOTE(Joe Sharp @ May 4 2006, 03:31 PM)
"Acronym"
and i think it is affectionately called a taco plate because it "taco's" when you over tighten the 2 bolts.... and after it taco's it leaks...
no one likes leaky taco's
SLITS
May 4 2006, 04:49 PM
039 101 267 - cover for temperature sensor for oil sump 021 101 269 A - sealing ring for cover 039 101 287 - gasket for temperature sensor 039 101 275 - protection cap temperature sensor cover oil sump 039 101 203 - cable holder temperature sensor N 013 803 2 - sealing ring for hexhead bolt N 010 210 13 - bolt hexhead M6X10 K
That's about all the parts that comprise the T.A.C.O plate assembly.
Been into the Cassadores a little early there Joe?
SLITS
May 4 2006, 04:51 PM
QUOTE(Aaron Cox @ May 4 2006, 03:39 PM)
"Acronym"
Been "South of the Border" dating again Aaron?
type47
May 4 2006, 05:27 PM
cover for telethermometer?
