911/930 Era Speedometer in my 914 ?, Size / fitment |
drive-ability |
May 5 2006, 11:22 AM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
Guys will a 911/930 speedometer fit in my 914 I/P ?
I need a electronic speedometer and understand its electrically different etc. Thanks John |
Cap'n Krusty |
May 5 2006, 11:32 AM
Guys will a 911/930 speedometer fit in my 914 I/P ? I need a electronic speedometer and understand its electrically different etc. Thanks John The 911 speedo drops right in. As for "electrically different", I guess you could say that. The electronic units are electronic, the older ones are mechanical. You'll need a sender, and it needs to be matched to the speedo. There is one for the later sportomatics, but it costs $160 and turns the wrong direction (which MIGHT not matter, as it's an impulse sender). The Cap'n |
drive-ability |
May 5 2006, 11:38 AM
Guys will a 911/930 speedometer fit in my 914 I/P ? I need a electronic speedometer and understand its electrically different etc. Thanks John The 911 speedo drops right in. As for "electrically different", I guess you could say that. The electronic units are electronic, the older ones are mechanical. You'll need a sender, and it needs to be matched to the speedo. There is one for the later sportomatics, but it costs $160 and turns the wrong direction (which MIGHT not matter, as it's an impulse sender). The Cap'n Thanks, I was hoping it would fit in the I/P hole, Its a 200 mph electronic unit and will work with my 930 transmission. (IMG:style_emoticons/default/clap56.gif) John |
Lo-Fi Version | Time is now: 15th May 2024 - 03:39 PM |
