Gauge in center console hole - different size, Quick and dirty tip |
Rand |
May 5 2006, 01:56 PM
I installed a head temp gauge in my center console where the clock used to be. (Got a good deal at CB Performance.)
But there are two common sizes (3 1/8 or 2 1/16), neither of which fit the factory hole in the center console. I didn't want to cut the console, so I went with the smaller size. My solution was readily available at Trekkor's favorite supply house. Picked up a short piece of ABS pipe at Home Depot. (IMG:style_emoticons/default/wink.gif) Cut a sleeve the length of the gauge body. It fits perfectly over the gauge. Put a little bit of black tape in between to snug it up. Then the combo fits perfectly in the stock hole. Attached image(s) |
jim_hoyland |
May 5 2006, 02:01 PM
Get that VIN ? Group: Members Posts: 9,287 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Nice touch ! Can you explain a little about the installation of the sender.
Rand |
May 5 2006, 02:05 PM
The sender is just a ring that fits around a spark plug. I installed it under #3. Came with a long set of wires... fed them through the firewall and center tunnel and cut to length.** Piece o' cake.
(IMG:http://www.ultralightnews.ca/cht/images/WES712-4WK_small.jpg) **[EDIT - actually did not cut - coiled up the excess like you are supposed to! (IMG:style_emoticons/default/biggrin.gif) ] |
StratPlayer |
May 5 2006, 04:21 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
If you noticed on the install instructions it said not to cut the length of the wires from the sender to the gauge.
Rand |
May 5 2006, 05:00 PM
Good catch StratPlayer....
The funny thing is I actually did note that and did NOT cut the wires!!! (IMG:style_emoticons/default/laugh.gif) Geez... It's been a while since I did this. (IMG:style_emoticons/default/wacko.gif) I remembered the wires being extra long but forgot that I actually wrapped up the excess and left it in a bundle behind the panel... Attached image(s) |
Eric_Shea |
May 5 2006, 05:05 PM
If you actually read the instructions it says not to wrap up the excess and leave it in a bundle behind the panel... (IMG:style_emoticons/default/w00t.gif)
So, that's 2 1/16th then? I want to mount my GT Gas gauge on the radio filler plate and I was thinking that and JB Weld oughta hold it for a while... cover with basket weave and away we go. |
Rand |
May 5 2006, 05:06 PM
If you actually read the instructions it says not to wrap up the excess and leave it in a bundle behind the panel... (IMG:style_emoticons/default/w00t.gif) So, that's 2 1/16th then? I want to mount my GT Gas gauge on the radio filler plate and I was thinking that and JB Weld oughta hold it for a while... cover with basket weave and away we go. (IMG:style_emoticons/default/laugh.gif) Well actually now that I think about it, I wrapped the excess around the steering wheel. Don't have the photo, so you'll have to take my word for it. (IMG:style_emoticons/default/laugh.gif) Dude, if you cover it with basketweave it will be really hard to read! (IMG:style_emoticons/default/tongue.gif) Yup, 2 1/16. |
Cap'n Krusty |
May 5 2006, 05:24 PM
If you actually read the instructions it says not to wrap up the excess and leave it in a bundle behind the panel... (IMG:style_emoticons/default/w00t.gif) That's right! You have to either move the engine to the rear 3 or 4 feet, or extend the chassis by welding in a section. The Cap'n |
Tobra |
May 5 2006, 05:26 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Cool idea, I was thinking black rubber hose, but I like this better
I really need to install my console and get a CHT guage. |
Eric_Shea |
May 5 2006, 07:42 PM
Joe Bob |
May 5 2006, 08:18 PM
The old 914 gauges were 2 1/8....the new ones will fit and usually come with a reducer ring to fit the older holes...or you can use 100 mph tape like you did....
McMark |
May 5 2006, 08:21 PM
If you actually read the instructions it says not to wrap up the excess and leave it in a bundle behind the panel... (IMG:style_emoticons/default/w00t.gif) That's right! You have to either move the engine to the rear 3 or 4 feet, or extend the chassis by welding in a section. The Cap'n You mean all that's available now is the CHT setup for a 914 Limo? (IMG:style_emoticons/default/lol2.gif) |
jim_hoyland |
May 5 2006, 09:42 PM
Thanks. The ring that goes under the plug has one wire running to the gauge; how does it measure temp ?
StratPlayer |
May 5 2006, 09:50 PM
The was a thread on that topic a while back. Do a search for CHT and you'll get the answer. I remember reading about how it measures tempature.
Rand |
May 5 2006, 10:50 PM
Thanks. The ring that goes under the plug has one wire running to the gauge; how does it measure temp ? Actually there are two wires inside that sheath. What you don't see in that photo is the red and black wires emerging from the sheath and going into the connector. |
BarberDave |
May 6 2006, 03:46 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
This is probbly the Dumb A-- Ques. of the day!!
Why a CHT on just one head,why not both. I know the #3 cly thing,and uneven air flow over both heads ,so why not one on each bank? Dave |
Joe Bob |
May 6 2006, 07:43 AM
Nothing says ya can't.....
Lo-Fi Version | Time is now: 14th May 2024 - 08:15 AM |
