Nice spring day, Thought I'd take my first drive of the season - NO! |
Pat Garvey |
May 7 2006, 07:53 PM
(IMG:style_emoticons/default/mad.gif)
These are the woes of a garage queen! New battery! 70 degree day! Top comes off! Fire it up! Spews guts!!!!!!!!!! Yep, my pristine 914, like a newborn baby, blew everything it could onto the garage floor before I could even get it out into the fresh air! Let it warm up after staring & within 15 seconds smelled fuel! Shut it down, found a clamp that had softened up over the winter & tightened it. Restart..........fine! No fuel leaks, but the garage floor was becoming Anwaar! Oil spewing everywhere on the drivers' side! Looks like it's coming from #1 cylinder, at the seal from the head & barrel. I took the engine apart 10 years ago, to fid out how it worked. Could itbe that I didn't properly torque te heads? If so, why did it take 10 years to mainfest itself - have had a MINOR leak since. Now, it's a gusher! Bummer! Before I R&R the unit, anyone know of a way to get to the crush sleeve between the cylinder heads & case without R&R'ing the motor. As I get older, it becomes more & more difficult to do these things!! Input please? Cross post OK. Looks like my season may be done before it started! Car ran great for 15 seconds! |
JeffBowlsby |
May 7 2006, 08:00 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Engine should come out if its as you describe. Its too confined in there to make it easy to repair while installed. Sure its not just the pushrod tube seals gone bad?
We know you would feel better pulling the drive train and detailing anyway... |
McMark |
May 8 2006, 12:37 AM
Oil should NOT be coming from between the cylinder and the head, ever. You'd hydrolock your engine if there was that much oil. If it's coming from the head side of the cylinder, it's more likely a pushrod tube seal. If one of those split it'll leak pretty good.
P.S. this is exactly why we avoided multiple forums. technically this is a garage type question since it has nothing to do with concours. the more forums we have the more we have to move stuff around because "it's in the wrong place" and the more whiners we have PMing us complaining about threads in the wrong forums and people posting BS like "take it to the garage". I'm not going to move this thread, but I couldn't resist taking the opportunity to try and explain our position. (IMG:style_emoticons/default/dry.gif) |
tod914 |
May 8 2006, 07:46 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Maybe the oil sender on the top? or the oil filler gasket.. (had that problem already and couldnt figure out why it leaked so much). Just a couple easy ones to check before you start pulling.
SirAndy |
May 8 2006, 12:44 PM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
P.S. this is exactly why we avoided multiple forums. technically this is a garage type question since it has nothing to do with concours. the more forums we have the more we have to move stuff around because "it's in the wrong place" and the more whiners we have PMing us complaining about threads in the wrong forums and people posting BS like "take it to the garage". I'm not going to move this thread, but I couldn't resist taking the opportunity to try and explain our position. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/agree.gif) i'm going to move this into the garage, where it belongs ... (IMG:style_emoticons/default/rolleyes.gif) Andy |
Lo-Fi Version | Time is now: 20th May 2024 - 06:50 AM |
