Thermostat Bellows Movement Question?, ...from largest to smallest - how much |
vesnyder |
May 8 2006, 08:46 AM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
Installing a new/old thermo and was wondering how much movement I should see from the largest to the smallest - without any spring force on the bellows? I am only seeing about a half an inch? The potential issue is when it is contracted - cold? Does not seem to get max movement out of the cooling flaps. Any experience here?
Joe Ricard |
May 8 2006, 09:12 AM
From full cold to full hot is not really that much.
You gain movement from mechanical advantage of the arm on the operating rod of the flappers. |
davep |
May 8 2006, 12:50 PM
914 Historian Group: Benefactors Posts: 5,144 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
That sounds about right. The collapsed bellows is as small as it gets, and the bellows frame limits the maximum size.
Lo-Fi Version | Time is now: 20th May 2024 - 01:12 PM |
