DaveP (or anyone else with cross-pollination experience), VW Brakes |
Eric_Shea |
May 8 2006, 02:05 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Which model and year VW's use the same front brake calipers we do? 411? Ghia? Trying to put together a one-off 205mm pattern system.
Thanks! |
lapuwali |
May 8 2006, 02:16 PM
Try the Type IIIs. I haven't measured, but they (and the rotor) look exactly the same.
'68-on, I think. |
davep |
May 8 2006, 03:48 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The VW 411, 412 uses the same front calipers and rotors. Type 3 and Ghia calipers are smaller. I'm doing a bunch of them also. Ghia calipers come in both 1 and 2 pin styles, but the pistons are smaller, 40mm I think. The 2 pin types are common and cheap, the 1 pin types are NLA, hence the need to rebuild them.
pokey1168 |
May 8 2006, 04:51 PM
Member Group: Members Posts: 158 Joined: 3-July 05 From: Pampa,Tx Member No.: 4,369 |
arouns 70-71 Type III are the same. They changed the bolt spacing in the later years I think. I wish I had some of the narrow pattern, That is what the disc brake kits for VWs are using. My 71 Type III's calipers would fit, I tried. On the high side, I now have 4 extra calipers for the 914. (IMG:style_emoticons/default/smile.gif)
Tobra |
May 8 2006, 07:10 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
arouns 70-71 Type III are the same. They changed the bolt spacing in the later years I think. I wish I had some of the narrow pattern, That is what the disc brake kits for VWs are using. My 71 Type III's calipers would fit, I tried. On the high side, I now have 4 extra calipers for the 914. (IMG:style_emoticons/default/smile.gif) I thought that stuff looked familiar |
davep |
May 9 2006, 06:30 PM
I understand that the early Ghia calipers I am rebuilding are 40mm bores. The later type III did go to the 411/914 calipers, probably 71 to 74 MY's.
Lo-Fi Version | Time is now: 31st May 2024 - 10:35 PM |
