> ride height, how low can you go?
stephen7
post May 8 2006, 02:27 PM
The 140 lb weltmeister springs I have are supposed to lower the car an inch but I think there is travel room to be lower. What is the preferred method for going lower in the rear? Cutting?
In the front I can adjust the torsion bars to go as low as needed right? I haven't done it but it looks pretty simple. Any other methods?
thanks
steve
Joe Ricard
post May 8 2006, 02:31 PM
CUMONIWANNARACEU
till your floor jack don't fit no more.
general rule of thumb is keep the A-arm parralell to the ground. and a slight forward rake.
post May 8 2006, 02:54 PM
Resident German
you'll need a set of adjusteable perches for the rear ...
low is gud until you run out of shock travel. then low is dangerous ...
(IMG:style_emoticons/default/smile.gif) Andy
Mueller
post May 8 2006, 05:03 PM
914 Freak!
for the rear, the correct method is to use adjustable perches like Andy mentioned....
Koni Yellow and Bilstiens come standard with grooves in the shocks that allow you to move the perch up and down in about .50" to .75" increments with the use of a cir-clip
For fine tuning, threaded collars are sold for the Konis and Bils. or if you are cheap like Mike, you adapt threaded collars to your stock Boge shocks.
(IMG:http://www.914world.com/bbs2/uploads/post-2-1119289815.jpg)
thread with part numbers and links
- Lo-Fi Version Time is now: 7th July 2026 - 05:56 PM
