My First Welds!, Sway Bar Brackets! |
Jeffs9146 |
Sep 24 2003, 04:51 PM
OK I did it! My first welds! They are not perfect but I did it!! I rented a Mig with gas from the local rental yard $25 and 20 minutes later its done!
Jeff Attached image(s) |
Mueller |
Sep 24 2003, 05:07 PM
That would explain the smoke I saw on the other side of the hills (IMG:style_emoticons/default/smile.gif)
Next time let me know, my welder is small enough for me to throw in the back of my car if you want to borrow it. Looks good for a rookie (IMG:style_emoticons/default/beerchug.gif) |
Sep 24 2003, 05:31 PM
now you have to learn the most important thing to become a professional welder.
how to operate that grinder (IMG:style_emoticons/default/laugh.gif) grind those welds down and seal them. "Metal-Ready" works very well ... Andy |
ChrisReale |
Sep 24 2003, 05:40 PM
Cool. Welding is on my list of things I need to learn how to do.
seanery |
Sep 24 2003, 05:44 PM
Chris, I took a class offered by the local high school's vocational department.
I learned Stick, MIG & TIG as well as the use of plasma cutters, etc... It cost me under $300 and was well worth it. |
Jeffs9146 |
Sep 24 2003, 05:53 PM
I do need a grinder! My dremmel is a bit to smalllllll! The welder I rented was only about 12"x18" with a 5 pound gas bottle strapped to it! Very compact! I did a few test welds on an old rear hood that I couldn't give away last winter and jumped right in! Does anyone have a smilie with a welding mast on it? lol
QUOTE Next time let me know, my welder is small enough for me to throw in the back of my car if you want to borrow it. I will call you next time Mueller! Jeff |
fiid |
Sep 24 2003, 06:05 PM
QUOTE(Jeffs9146 @ Sep 24 2003, 03:53 PM) I do need a grinder! My dremmel is a bit to smalllllll! The welder I rented was only about 12"x18" with a 5 pound gas bottle strapped to it! Very compact! I did a few test welds on an old rear hood that I couldn't give away last winter and jumped right in! Does anyone have a smilie with a welding mast on it? lol QUOTE Next time let me know, my welder is small enough for me to throw in the back of my car if you want to borrow it. I will call you next time Mueller! Jeff Home despot will sell you a 4" Ryobi grinder for about $30. I've given mine some abuse and it seems to be up for it. I would recommend it. WTF is this weld sealing stuff you are talking about Andy - do you have a link? is this stuff for making welds watertight and making them look a bit better? Thx, Fiid. P.S. 111th Post. Wasn't there a Lotus Elise 111R or something?? |
Sep 24 2003, 06:13 PM
QUOTE(fiid @ Sep 24 2003, 05:05 PM) WTF is this weld sealing stuff you are talking about Andy - do you have a link? is this stuff for making welds watertight and making them look a bit better? metal-ready is part of the POR-15 treatment but works well as a standalone too ... creates a zinc phosphate coat over the bare metal. http://www.por15.com/product.asp?productid=177 Andy |
Jeffs9146 |
Sep 24 2003, 07:10 PM
I just went out and purchased a Makita 4" grinder! It should go quick from here!
Jeff |
John Kelly |
Sep 25 2003, 08:46 AM
Senior Member Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 |
Hi Jeff,
Good for a first timer! It looks like you need to weld a little hotter so that the weld flattens out and blends in to the metal better. You want a round flat puddle to form each time you press the trigger. Press the trigger and release. It takes about 1 second, then move on to the other side away from the weld you just did. Keep zapping like this until you have filled in everywhere. Each small flat puddle should overlap the one next to it. Sometimes it helps to "wash" a little. This is simply moving the wire from one side across the gap or seam to the other in order to flatten it out. This also allows you to carry more heat without burning through. No grinder should be needed unless you are doing body work, and then gas-welding, or Tig is a better choice, and can be done with little or no grinding if done correctly. John www.ghiaspecialties.com |
Jeffs9146 |
Sep 25 2003, 09:28 AM
Thanks John!
I think the sections that are raised are where I was unstable and pulled away from the weld surface and kept welding! I found that if I was closer I was able to achieve the "flow" and as I moved away it cooled faster. Just a guess though! Jeff |
Dave Avery |
Sep 25 2003, 11:25 AM
Unregistered |
Takes a humble man to post pics of his welding (IMG:style_emoticons/default/wink.gif)
I usually grind mine flat and paint before I'll even let my kids look at it (IMG:style_emoticons/default/wink.gif) |
Queenie |
Sep 25 2003, 11:54 AM
Society Is A Hole Group: Members Posts: 383 Joined: 14-July 03 From: SLO-CA Member No.: 908 |
QUOTE(seanery @ Sep 24 2003, 03:44 PM) Chris, I took a class offered by the local high school's vocational department. I learned Stick, MIG & TIG as well as the use of plasma cutters, etc... It cost me under $300 and was well worth it. Another good option is your local community college. That's where I took my welding class! |
Jeffs9146 |
Sep 25 2003, 04:23 PM
I never said I was a welder so it doesn't matter what they look like as long as they work....right (IMG:style_emoticons/default/confused24.gif)
Jeff |
Dave Avery |
Sep 26 2003, 07:35 AM
Unregistered |
QUOTE I never said I was a welder so it doesn't matter what they look like as long as they work....right Heh... I wasn't commenting on yours, commenting on my frankenstein welds. At least some of my problem is that my welder has a rusty liner, and the wire "pauses" and breaks the arc all of the time. |
dharder |
Sep 28 2003, 04:27 PM
Newbie Group: Members Posts: 6 Joined: 28-September 03 From: Tahoe, CA Member No.: 1,207 |
Now, what about the rear sway bar?? Welding, without flinching, while slag is dripping onto your chest takes real courage.
seanery |
Sep 28 2003, 04:42 PM
no slag with a mig!
really super clean with a tig!!! (IMG:style_emoticons/default/smile.gif) |
Air_Cooled_Nut |
Sep 28 2003, 11:07 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
QUOTE No grinder should be needed unless you are doing body work, and then gas-welding, or Tig is a better choice, and can be done with little or no grinding if done correctly. Hmm, for a beginner I have to disagree about gas welding body metal...and TIG is simply too expensive. I think MIG is fine for a variety home jobs and gas is nice and serves a purpose (brazing, cutting, forming and welding) but not to beginner sheet metal welding on a car. As for working on modern cars a MIG welder is recommended over gas due to the modern metals being used. |
John Kelly |
Sep 29 2003, 09:03 AM
Hi Toby,
I started out gas-welding on a Ghia in the late '70s or early '80s. I was a ship yard welder using stick and inner shield wire at that time. Also had a lot of experience welding with mig. I listened to what others said about mig-welding being the best way to go and switched to mig on cars. Later I wished I had not. Mig is great if you only plan to go so far, or are a home hobbiest, but to develop the skills further, gas-welding is well worth the extra effort to learn. After many years of experimentation with methods of trying to keep shrinkage down while mig-welding, I finally switched back to gas-welding for most of my work. The metal stays soft and workable unlike a mig-welded panel which seems to be work-hardened, and requires grinding. I can actually do my projects faster with gas than mig, and have no hesitation about cutting through a gas-weld with a pair of aviation snips, using a hammer and dolly extensively if necessary, or hammer-forming a part that has been gas-welded, all of which would be problematic with a mig weld. A mig weld is like a stiffener in the middle of a panel. A gas weld is much like the rest of the metal after a small amount of hammer and dolly work. So, I agree, for beginners mig is great, but it can lead to arrested development, and more bondo than necessary. I've met a lot of great metal workers online, and in person, and only one of them uses mig for top quality autobody work with no filler. He grinds both sides, and uses a hammer and dolly to straighten, and reduce shrinkage. Everyone else that I know of in metalshaping uses either tig or gas-welding. I think the reason gas-welding has gotten a bum rap is that the metal moves so much. The trick is that it will come back with a few bumps from a dolly, and some on-dolly stretching of the weld. Mig-welding appears to make the metal move less initially but it actually pulls, shrinks, and hardens the weld area to a greater degree. Sometimes the old ways are better! John www.ghiaspecialties.com |
Air_Cooled_Nut |
Sep 29 2003, 09:56 AM
Cool John (IMG:style_emoticons/default/smile.gif) So, for gas welding 914 sheet, what do you use? Brand name and tip sizes, por favor (IMG:style_emoticons/default/chatsmiley.gif)
Lo-Fi Version | Time is now: 21st May 2024 - 10:01 AM |
