Nice Forum! I want my first post here to be about:, WEIGHT... (a bunch of cars out there need to get #'s) |
race914 |
May 20 2006, 09:56 AM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
Currently at 1980lbs with 1/4 tank and no driver. Still have stock trunk lid, headlight motors, full interior, etc. Next project is fiberglass trunk lid/spoiler. |
brokenmoped |
May 20 2006, 07:54 PM
Member Group: Members Posts: 143 Joined: 27-May 05 From: Mission Viejo, CA Member No.: 4,152 |
Never had the chance to weigh mine...
1974 2.0, front and rear sway bar, koni red all 4, 140lb springs, 2.0 fuchs, FG hood, rear lid, roof, front bumper and rear bumper, all sound deadening stripped, no radio, full interior, both seats, and a rollbar... I'm guessing around ~1900. Anyone have a better guestimate? |
retrotech |
May 20 2006, 08:06 PM
retrotech Group: Members Posts: 470 Joined: 2-November 03 From: Mosier, Oregon Member No.: 1,302 |
Does anyone know the "actual" weight savings, using Lexan windows?
I have been considering it. Comments? |
J P Stein |
May 20 2006, 10:06 PM
Does anyone know the "actual" weight savings, using Lexan windows? I have been considering it. Comments? Windows is for computers, not race cars (IMG:style_emoticons/default/biggrin.gif) Actually, I do still have a front window, but if you turn your back, it may be gone. Some time back there was a thread on the garage on plexiglass windshields and a link to a supplier. The plastic windshield was about 400 bucks and the weight savings was around 15-20 lbs.....not too bad. |
brant |
May 22 2006, 11:43 AM
914 Wizard Group: Members Posts: 11,619 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
QUOTE Why not truck scales? (IMG:style_emoticons/default/confused24.gif) I know the ones down here at the dump are accurate within 20#'s. Sometimes I'll be weighing in or out and the scale will teeter back and forth between xx20-xx40, for example. Within 20#'s is good enough for me for "just knowing". Corner balance- Whole different thread. (IMG:style_emoticons/default/wink.gif) KT here is my opinion on why NOT truck scales. Scales are calibrated to be accurate within a certain range. When i worked in a grain warehouse we used to have the state inspector come in and recalibrate and certify our scales regularly... If you overloaded a scale that was designed to weigh an 80lb bag, it would potentially throw off the calibration. same thing if you drove a 10,000 lb truck onto a 3,000lb corner balancing car scale. Probably ruin it. for the same reason a truck scale is calibrated to work accurately with a 20,000 truck. It IS NOT going to be very accurate at 2,000 lbs. It might be 1% off but that is 200lbs difference at 1%. The truck scale at the dump is probably not even regularly calibrated if it is even calibrated it is being used outside of its operating range. If you want to guess within 200 lbs.. thats fine... but I personally don't trust truck scales and would much rather hear about accurate and repeatable numbers. my $.02 brant |
brant |
May 22 2006, 11:45 AM
Hay Brant. I'm finally getting around to removing the floor tar from my car(humm, poetry (IMG:style_emoticons/default/biggrin.gif) ) Got it bout half done & there's 7 lbs of road hugging weight in the pail. Lessee 1848-7.....er... carry the 2....1841. Also got rid of the pass seat & adjuster goodie.....maybe 10 lbs tops. 1831 & dropping. I can see the 17xxs in my future....less windshield, dash & asociated shittage. The upper section of the cage is also in the crosshairs. Then....I have a selection of hole saws...I also see E Mod in my future (IMG:style_emoticons/default/huh.gif) I fear I will not be able to catch you and must admit defeat.. ( I have about 10-15 lbs worth of projects planned ) brant |
jhadler |
May 22 2006, 11:47 AM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Hey Brant, all that sun in La Junta must have cooked yer noggin a bit. 1% of 2,000 lbs is 20 lbs,, not 200... (IMG:style_emoticons/default/biggrin.gif)
Still, truck scales are not going to be very accurate for a 2,000 lb car. -Josh2 |
brant |
May 22 2006, 11:51 AM
Hey Brant, all that sun in La Junta must have cooked yer noggin a bit. 1% of 2,000 lbs is 20 lbs,, not 200... (IMG:style_emoticons/default/biggrin.gif) Still, truck scales are not going to be very accurate for a 2,000 lb car. -Josh2 I was thinking 1% of a 20,000 truck... meaning that the truck may be off by 200lbs and they (the dump or D.O.T.) probably don't care about that amount. I didn't do a very good job of making my point. brain was going in 2 directions at once. I theorize that the scales are way more than 1% from accurate, when used outside of their given range... All you rocket scientists at NCAR probably know more about this than I. what do you think Josh.. aren't scales designed to only be accurate within a range? brant |
jhadler |
May 22 2006, 12:07 PM
All calibrated devices are generally calibrated to work within a range that they are designed to be used for. You wouldn't use a bathroom scale to weigh a letter that you're sending by mail?
Granted, the wight of a 2,000 lb car is a lot closer to the range of use of a truck scale than a letter is to a bathroom scale. But it's likely that the scale is not calibrated for use at that low a weight. What does it mean? It -could- mean that your measurement is waaaay off. It could also mean that your measeurement is spot on. There's no way to know. If I just wanted to know -roughly- how much my car weighed, a truck scale would tell me fine. But if I'm trying to make minimum weight for a competition class, the truck scale is likely to land me in the impound shed, with a protest sheet on the window... And even then, corner scales will only be accurate if they're properlly setup and calibrated. -Josh2 |
Aaron Cox |
May 22 2006, 12:41 PM
weighed mine at joe sharps house. 1 gallon of fuel, and no front bumper...
1908 lbs. all metal.... |
Trekkor |
May 22 2006, 11:25 PM
The scales at our dump weigh a wide variety of vehicles.
Little mini econo-cars with a small load in the trunk to the largest triple axled trailered dumping big-rigs. It's pay by wieght. Wiegh in . Wiegh out. Every 20# is theirs. (IMG:style_emoticons/default/wink.gif) I hope somebody is regulating them. Anyway...I'll post my real wieght after I get on some car scales. KT |
Joe Ricard |
May 23 2006, 04:57 AM
I need to go down to the roundy round shop and have them give me a baseline. Then I can record everything I take off and put back on. Hopefully keep track for a few more years.
9146R |
May 25 2006, 11:17 AM
Member Group: Members Posts: 223 Joined: 28-September 04 From: alamo ca Member No.: 2,849 |
Here are the figures on 914-6R... Orig six with 2.4 motor, f'glass hoods f&r, f'glass bumpers damn in front, interior, headlites & heater deleted, 2 OMP race seats, 15x7 Cookies with Toyo RA1's, coil over rears with 250 lb springs. Bilstein greens in front.
vehicle weight with qtr tank gas 2080, with 180lb driver 2260 lbs Front wt 965 lbs Rear wt 1295 lbs Driver front 512lbs 22.8% Pass front 454 lbs 19.9% Driver rear 687lbs 30.2% Pass rear 608lbs 27.1% Left side 1199lbs 53% Right side 1062 47% Greg |
smdubovsky |
May 25 2006, 12:05 PM
Member Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
It's pay by wieght. Wiegh in . Wiegh out. Every 20# is theirs. (IMG:style_emoticons/default/wink.gif) I hope somebody is regulating them. KT Those scales dont need to be accurate (they only need to be precise - look up the difference;). Heck, they only need to be repeatable - they can be 500lb off going in as long as they are the same 500lb off going out. Truck scales aren't accurate... SMD |
9146R |
May 25 2006, 12:50 PM
Here are the figures on 914-6R... Orig six with 2.4 motor, f'glass hoods f&r, f'glass bumpers damn in front, interior, headlites & heater deleted, 2 OMP race seats, role bar/cage, 15x7 Cookies with Toyo RA1's, coil over rears with 250 lb springs. Bilstein greens in front.
groot |
Jun 8 2006, 06:11 AM
Dis member Group: Members Posts: 894 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
Swapped out my 37.5 pound steel hood for a 11.1 pound fiberglass version.
Swapped out my 35.5 pound steel trunk lid for a 11.1 pound fiberglass version. ~50 pound weight save. Now, I'm sitting at 1650 with no fuel or driver. |
brant |
Jun 8 2006, 07:58 AM
Dang... Kevin....
that is awesome! brant |
Lo-Fi Version | Time is now: 5th May 2024 - 06:36 AM |
