Optima yellow top deep cycle |
iamchappy |
May 16 2006, 08:15 PM
I am considering replacing my red top with a yellow top, Reason being I will be running 2 - 7" fans for my intercooler, a Tilton transmission pump for my tranny cooler and my 2 - 8" sub , 6.5 and 5.25 speakers powered by my Alpine head unit and 2 Alpine amps along with the normal power accessories than run the car.
Do you think I would benefit switching to a Yellow top deep cycle for my set up and additional electrical drains. (IMG:style_emoticons/default/confused24.gif) |
Rand |
May 16 2006, 08:21 PM
I thought a deep cycle was made to charge up, then run down... ie they don't like constant charging like a regular car battery.
I don't know about the yellow tops, but just something to check out. |
Howard |
May 16 2006, 08:40 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
I thought a deep cycle was made to charge up, then run down... ie they don't like constant charging like a regular car battery. I don't know about the yellow tops, but just something to check out. (IMG:style_emoticons/default/agree.gif) I believe they are for marine and golf cart use. |
Rand |
May 16 2006, 08:43 PM
How about a higher output alternator? I think a club member here builds/sells them.
edit: Found it, davep: high amp alternator |
May 16 2006, 08:44 PM
I had a yellow-top fail after about a year and a half in my Honda. Several other Honda folks had similar experiences. (The only Optima that is the same size as the stock battery in that car is a yellow-top.)
The quality of the yellows seems to be less than great. --DD |
iamchappy |
May 16 2006, 08:52 PM
I just picked up a used car for my son and it needs a battery so I was thinking about throwing my red top in his car and picking up a new one for myself. While I was picking up goodies at Costco today there was a yellow top Optima screaming at me to take it home and made me wonder.
akellym |
May 16 2006, 09:14 PM
Eyes Of The Deep Battle Group: Members Posts: 597 Joined: 25-July 04 From: Annandale, MN Member No.: 2,395 Region Association: Northstar Region |
I've had a yellow for three years and it's still working great.
bmcwilli |
May 16 2006, 09:17 PM
Member Group: Members Posts: 133 Joined: 28-April 05 From: Chapel Hill NC Member No.: 3,998 |
I dunno if the yollow is truly a deep cycle. A deep cycle is designed to be more tolerant of deep discharges, while a cranking battery should never be deep discharged.
Don't think a deep cycle is what you;re looking ofr/ Most recommendations are to not let a deep cycle go below 20%. Also, I belive the yellow top requires a different charging regime and max voltage than standard cranking batteries. I odn't know if Odyssey makes a battery that fits, but their AGM (absorbed glass mat) batteries are great. Check em out.. www.odysseybatteries.com |
Tobra |
May 17 2006, 01:30 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Odyssey is what NAPA sells, I think. The meatbag I talked to down there said they did not make one with the poles reversed, like for a 914.
hcdmueller |
May 17 2006, 01:47 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
I thought a deep cycle was made to charge up, then run down... ie they don't like constant charging like a regular car battery. I don't know about the yellow tops, but just something to check out. Definitely deep cycle. We use the yellow tops on some of our robotic equipment at work. They only consistently work well when we run them down and do a full recharge. I have seen several completely give up when they sit on a charger too long. |
akellym |
May 17 2006, 07:59 PM
okay here you go this is right from optimas web site. As you will see there is nothing wrong with using a deep cycle battery.
Advantages of the OPTIMA® Deep Cycle Battery: Delivers higher peak amps faster than conventional batteries Provides up to twice the life of conventional batteries More consistent voltage across the discharge curve Superior cold and hot weather performance vs. conventional batteries Available in models with SAE posts, stainless threaded studs, or both Spill-proof, even if the case is physically ruptured Will not off-gas in normal operation, eliminating fumes, odor & corrosion Over 14x more shock and vibration resistant than conventional batteries Provides more power from a smaller package True zero maintenance Holds charge better during periods of nonuse Operates in any position without spilling Offers proven durability & performance (Read testimonials) Selecting The Right Optima® Battery Optima® offers two basic battery types: Optima starter type batteries, and Optima dual-purpose deep cycle/starter batteries. The Optima starter type batteries are superior replacement units for your car, truck, boat, or other vehicle. Optima deep cycle/starter batteries serve dual purposes: They function very well as starter batteries, but they also are designed to withstand repeated deep discharging (down to a charge level of 10.5 volts) without having their life span shortened. This ability makes them especially useful when electrical loads exceed recharge rate (including times when the battery cannot be recharged at all, such as for marine trolling motors, or for running car audio equipment with your engine turned off.) Optima deep cycle batteries are very popular for marine trolling motors, winches, special lighting, portable power, and emergency backup systems of all types. If you need high performance power for car audio, the best battery for you is one or more of the largest Optima deep cycle/starter batteries you can fit in. |
iamchappy |
May 17 2006, 08:13 PM
So if I go with the yellow top deep cell then I dont have to purchase a better stereo system for my garage, i can just use the cars sound system all day long and the battery will be happier because of it. Stick the trickle on it overnight and I am good to go.
Or I could go get a high power alternator. Or I could do nothing and see how the red top handles the extra draw from the accessories. Yellow top looks to be a duel purpose battery that may be in the future for the car. |
lotus_65 |
May 17 2006, 08:22 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
I just picked up a used car for my son and it needs a battery so I was thinking about throwing my red top in his car and picking up a new one for myself. While I was picking up goodies at Costco today there was a yellow top Optima screaming at me to take it home and made me wonder. you got him a cayenne, fresh off lease, and it's got a dead battery?! (IMG:style_emoticons/default/wavey.gif) |
iamchappy |
May 17 2006, 08:35 PM
Wrong son I have 4 of them. Ollie wants the Cayenne, My wife wants a Maserati, My daughter wants a Range Rover, my youngest says he would be happy with a Geo, and my oldest gets the junker free car. And the middle son gets none he has to earn it......
All I want is my 914 and man do I get grief over it. |
iamchappy |
May 24 2006, 07:28 PM
I picked up the yellow top, I figured with all the extra electrics I have running and the huge power drain with the electric heater I use in the Fall, I think this may cover me for awhile if the alternator cant keep up.
Allan |
May 24 2006, 07:32 PM
Does your teener float?
turboman808 |
May 24 2006, 08:03 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
Just wanted to add I picked up a oddesy battery for another car and it works really sweet. I got a smaller light weight one. I just got to make a battery box for it.
The racecar 914 from this weekend had the same small oddessy in the passenger side. If the optima in the 914 ever dies I will get one of these for it. |
Lo-Fi Version | Time is now: 3rd May 2024 - 04:53 PM |
