Removing Oil Stains, Tell me your method |
Mr.C |
May 17 2006, 06:16 PM
Easy does it Group: Members Posts: 611 Joined: 31-December 02 From: Central Cal Member No.: 61 Region Association: None |
That's right, I want to know your method. I have these nasty old diesel oil stains in pourous concrete that I need to get up.
(IMG:style_emoticons/default/teef.gif) My house looks like he lives here. Sometime back I heard of using gasoline and then kitty litter. Does this work pretty good or would paint thinner work better? I'm tired of my driveway looking like crap so help a guy out! |
Mike McGrath |
May 17 2006, 06:28 PM
Member Group: Members Posts: 98 Joined: 5-December 04 From: Portland, Oregon Member No.: 3,225 |
Just spill the rest of the oil on the other parts of your driveway and make it match. Speaking of matchs, can you burn off the oily residue? Try charcoal lighter fluid.
May 17 2006, 06:30 PM
brake cleaner ... apply generously, wipe off with cloth ...
werks great! (IMG:style_emoticons/default/smile.gif) Andy |
Mr.C |
May 17 2006, 06:31 PM
Just spill the rest of the oil on the other parts of your driveway and make it match. Speaking of matchs, can you burn off the oily residue? Try charcoal lighter fluid. Hmmm, now that's a thought. (IMG:style_emoticons/default/idea.gif) |
carreraguy |
May 17 2006, 08:02 PM
It's not your dad's 914! Group: Members Posts: 1,197 Joined: 17-October 03 From: San Jose, CA Member No.: 1,256 Region Association: Northern California |
Grind some kitty litter (hopefully clean) into the stain with your shoe and sweep it off. Works like a charm. (IMG:style_emoticons/default/biggrin.gif)
TROJANMAN |
May 17 2006, 08:15 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Grind some kitty litter (hopefully clean) into the stain with your shoe and sweep it off. Works like a charm. (IMG:style_emoticons/default/biggrin.gif) tide with bleach lightly water sweep with a broom or hands and knees scrub rinse and repeat |
So.Cal.914 |
May 17 2006, 08:22 PM
Acid bath directly followed by Tide w/ bleach. Used this to clean industrial kitchen floors before application of epoxy finish. If done correctly in cleans it to the bone. You can get the acid from hardware or paint store.
(IMG:style_emoticons/default/smoke.gif) |
mattillac |
May 17 2006, 09:00 PM
robots! Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
i posed the same question a while ago. another club member suggested
MEK. you can buy it at home depot. this stuff is FANTASTIC!!! it is pretty strong tho. cleaning process: 1. apply MEK to stain, use sparingly. 2. scrub stain with heavy brush. i used one attached to a broom stick. 3. apply more MEK as needed to remove stain. 4. soak up MEK with kitty litter. 5. sweep up and dispose of kitty litter. you can also make a kitty liter dam around the stain, works well also. i would use eye protection and gloves, this is strong stuff. don't breath too much, unless you dislike your brain cells. Methyl Ethyl Ketone do a search and you'll find the old thread. again, this works VERY WELL and does not hurt the concrete. acid bath might eat up your concrete. (IMG:style_emoticons/default/thumb3d.gif) |
Pat Garvey |
May 18 2006, 02:07 PM
Acid bath directly followed by Tide w/ bleach. Used this to clean industrial kitchen floors before application of epoxy finish. If done correctly in cleans it to the bone. You can get the acid from hardware or paint store. (IMG:style_emoticons/default/smoke.gif) Be VERY careful with this stuff! True, it will clean just about anything, but it is exremely dangerous. Not only is it believed to be cancer-causing, but it's highly volatile! Wear a very good respirator (not a dust mask) & be certain there are absolutely no sources for spark or flame anywhere near by. No electric motors, no water heaters,etc. Don't scrub with a wire brush, as it could spark. BE CAREFUL!! BTW, it does work. |
Tobra |
May 18 2006, 02:17 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
I thought MEK gave you liver cancer. Simple Green for me, works okay, won't make your liver fall out.
Allan |
May 18 2006, 02:32 PM
Acid won't work on petroleum stains. It just beads of.
The best thing I have found is to use some laundry powder. Liberally sprinkle it over the stain and stomp/grind it in really good. Let it sit for a day then add a little water. Scrub, scrub, scrub, scrub and scrub some more... |
brer |
May 18 2006, 06:56 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
I use M50 solvent.
not available at your local hardware store. |
jasons |
May 18 2006, 07:06 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
Oil Eater from Costco.
Brando |
May 18 2006, 08:12 PM
Muriatic acid and a pressure washer! 1700 PSI of powar.
Porsche Rescue |
May 18 2006, 08:59 PM
I like gas and kitty litter.
Lo-Fi Version | Time is now: 17th May 2024 - 04:09 PM |
