i posed the same question a while ago. another club member suggested
MEK. you can buy it at home depot. this stuff is FANTASTIC!!! it is pretty strong tho.
cleaning process:
1. apply MEK to stain, use sparingly.
2. scrub stain with heavy brush. i used one attached to a broom stick.
3. apply more MEK as needed to remove stain.
4. soak up MEK with kitty litter.
5. sweep up and dispose of kitty litter. you can also make a kitty liter dam around the
stain, works well also.
i would use eye protection and gloves, this is strong stuff. don't breath too much,
unless you dislike your brain cells.
Methyl Ethyl Ketone
do a search and you'll find the old thread.
again, this works VERY WELL and does not hurt the concrete. acid bath might eat up your concrete.
