New Seats Installed, GTS LeMans |
smdubovsky |
May 20 2006, 08:57 AM
Member Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
Garold,
Do you have probs w/ running the 5pts over the edges w/o built in harness holes? I never could tell fromt he pics how high the side bolsters really are (they look TALL). Im realtively tall and skinny and was worried they wouldn't pull tight down on the hip bones when I take it to the track. Could you take a pic w/ the harness on? SMD |
GTS |
May 20 2006, 01:37 PM
Member Group: Members Posts: 64 Joined: 7-October 04 From: South Austin,TX Member No.: 2,903 Region Association: None |
Hi All,
Thank you all for your comments on the seats.We hope do satisfy every customer as well in the future with each request.The only downside is the manufacturer timing as they run in Italy on Roman Time........ here a few more pictures for the 5 point and stock seatbelts.... |
pete-stevers |
May 20 2006, 03:05 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
i would love to have a pair in my car.....perhaps i will reward myself after it is running......mmmmm how can i talk "her" into this one
guywan914 |
May 20 2006, 04:48 PM
Member Group: Members Posts: 221 Joined: 27-May 04 From: Columbia,CT Member No.: 2,112 |
Those do look awesome, can't wait to get a set. Should be ready for them in a couple months. Save me a set please?
Cap'n Krusty |
May 20 2006, 06:10 PM
Great looking seats! Probably comfortable, and sure to be an improvement over the stockers. Nice colors, too. However, my lengthy experience with Audis makes me question the use of Alcantara. It was pretty much stock on the 5000 and 100 Quattros and has not proven to wear well. Still, if the car's not a daily driver, it should last a while. The Cap'n
JWest |
May 20 2006, 07:28 PM
Great looking seats! Probably comfortable, and sure to be an improvement over the stockers. Nice colors, too. However, my lengthy experience with Audis makes me question the use of Alcantara. It was pretty much stock on the 5000 and 100 Quattros and has not proven to wear well. Still, if the car's not a daily driver, it should last a while. The Cap'n Thanks for the input. A lot of car makers are using it now (even the new 911 GT3 has it), so hopefully there has been some improvement over what you have seen. If not, my 914 has been reduced to weekend/perfect day drives, so it should last a looong time for me. |
GaroldShaffer |
May 20 2006, 07:41 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Garold, Do you have probs w/ running the 5pts over the edges w/o built in harness holes? I never could tell fromt he pics how high the side bolsters really are (they look TALL). Im realtively tall and skinny and was worried they wouldn't pull tight down on the hip bones when I take it to the track. Could you take a pic w/ the harness on? SMD No problems at all. Holds my (IMG:style_emoticons/default/bootyshake.gif) in place. The seat bottom does have a opening for the nut crusher strap (IMG:style_emoticons/default/pinch.gif) |
jim_hoyland |
May 20 2006, 09:23 PM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
One last question; does the seat height change ?
VegasRacer |
May 21 2006, 04:43 AM
ELVIRA Group: Benefactors Posts: 8,524 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
914-8 |
May 23 2006, 10:44 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
The GTS LeMans seats are very, very nice.
The biggest difference between the LeMans and the stock seat is that rather than being a foam cushion sitting on fiberglass, the LeMans is a "sprung" seat. The cushion sits on a spring hammock type thing. Makes a HUGE difference being suspended like that. It does raise you up, though. Mine raised me up more than 3/16 over stock. Seemed to me closer to 1/2 inch. At 6 feet even, it was still comfortable to drive, but sat me up higher than I liked. But that's no problem. I simply figured out how much lower I wanted to be, removed the bottom cushion, cut it down 3/4 of an inch, and reassembled. An easy job, but you need an upholstery stapler to put it back the way it was. Took a couple of hours. I don't think an upholstery shop would charge much to do it. Since the seat height isn't adjustable, it's nice to have a "custom" seat that fits. As customized, the LeMans is AWESOME! To me, it's a "must have" for the 914. (IMG:http://img.photobucket.com/albums/v520/bak535/Picture132.jpg) (IMG:http://img.photobucket.com/albums/v520/bak535/picture131.jpg) |
szuccaro |
May 23 2006, 11:36 PM
ZUKE Group: Members Posts: 200 Joined: 27-June 03 From: Cameron Park, CA Member No.: 862 Region Association: Northern California |
Very, very cool!
BigDBass |
May 24 2006, 11:07 AM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
Anyone know if these can be done in brown? If so, I need to track down an $800 coupon! (IMG:style_emoticons/default/biggrin.gif)
JWest |
May 24 2006, 02:14 PM
Anyone know if these can be done in brown? If so, I need to track down an $800 coupon! (IMG:style_emoticons/default/biggrin.gif) Yes, just call Stefan - he can do anything you wish. The material I selected was just something I dreamed up and asked if he could do it. They sourced it and I bought a little extra to use on other parts of the interior. |
GTS |
May 24 2006, 07:33 PM
horizontally-opposed |
May 25 2006, 09:38 AM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
James,
One last question: E-brake interference? Thanks, |
JWest |
May 25 2006, 09:42 AM
GaroldShaffer |
May 25 2006, 11:58 AM
They are awesome seats. I'm not tall, only 5' 7" but I am wider than some people (220lbs (IMG:style_emoticons/default/blink.gif) ) and my fat (IMG:style_emoticons/default/bootyshake.gif) fits just fine. I liked this seat so much that I bought another over the winter for the passenger side.
BigDBass |
May 25 2006, 12:01 PM
Hi Dan, just as James said,we can provide you with all kinds of materials, colors and pattern and embroidery.Attached a few samples. Sweet, now I just need to find that $800 coupon. I bet it's right under the $300 RennShift coupon! (IMG:style_emoticons/default/smile.gif) |
smdubovsky |
May 25 2006, 12:10 PM
Does anyone have pics using these w/ a 5-pt with them SITTING in the seat? I still cant tell how high the bolsters are w/o a reference (I dont have the stock seat belts, so that pic doesnt help me any.)
Thanks, SMD |
GTS |
Jun 7 2006, 02:07 AM
Hi SMD,
here are some pictures from some customers..... regards Stefan |
Lo-Fi Version | Time is now: 7th June 2024 - 08:53 AM |
