1.8 Rebuild Won't Idle |
jwilliamadams |
May 20 2006, 09:47 AM
Will Adams Group: Members Posts: 28 Joined: 1-May 05 From: San Luis Obispo, CA Member No.: 4,010 Region Association: None |
Greetings,
I have rebuilt my 1.8 and at the same time used new slip in pistons and cylinders that were slightly larger (93x66mm, which I believe works to 1.9+L). The place I purchased them from (West Coast Core in CA) assured me that my L-Jet FI would still work great. Well, I can't get the damn thing to idle. I do not have any vacuum leaks (sure of it.) Timing and dwell are right on. Fuel pressure is good. It runs great past idle with all kinds of power. I have the idle adj screw all the way maxed. At this setting it maybe idles at 700RPM. I have a second air flow meter from same year (1974) that I know works and tried it out with same results. Is it possible that with the new p/c size they are needing more air at idle, more than can be sent through the current idle air port in the throttle assembly? Thanks for any help! |
Lo-Fi Version | Time is now: 15th May 2024 - 09:55 AM |
