The BIG Bang, ... and the clutch goes to the floor ! |
propricer |
May 20 2006, 11:09 AM
Member Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
Never heard of this one until it happened to me ... anyone ever have the clutch pivot ball break off right at its base ??? Running a 911 pull type clutch on my V8 / 901.
I've had the ball pull out of the case a couple of times and have fixed that one for good but this is a new one. Anyone ever had this happen ... with the clutch fork now floating, did it also take out the pressure plate ??? Thought this was a hardened part ... boy, what a NOISE when it went !!! |
Mark Henry |
May 20 2006, 11:17 AM
Most likely it's only the ball...it makes one hell of a bang, but it should be the only thing broke.
Mark Henry |
May 20 2006, 11:23 AM
BTW I've had to do this repair on 2 customers cars in the last 2 years, both pull type. Is your pedal real hard? Check your cable for binding.
Also do you have a pedal board? |
Cap'n Krusty |
May 20 2006, 11:41 AM
Common 2.2 911 failure. I've probably seen a dozen or more over the years. There have been numerous products on the market that attempt to address the problem, but I can't attest to whether or not they work. Might wanna check the thickness of the disc: major reason for the failure of the pivot. The Cap'n
Lo-Fi Version | Time is now: 14th May 2024 - 03:38 AM |
