what tool do i need? |
rcrgrl |
May 22 2006, 02:02 PM
Member Group: Members Posts: 202 Joined: 19-April 06 From: San Diego, CA Member No.: 5,893 |
what tool do i need to remove the 3 bolts holding the fan on? they look like allans, or the cv bolts, but with more points. i was hoping to swing by the tool store on my way home, but not knowin the name or size it would be a very unfruitful trip.
anybody know what i'm talking about? |
Mueller |
May 22 2006, 02:08 PM
same triple square used on your CV joints...8mm I think....
JeffBowlsby |
May 22 2006, 02:09 PM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Dont know about the bolts, but once the fan cage is off you will want one of these VW185 tools to take off the hub:
JeffBowlsby |
May 22 2006, 02:10 PM
It looks like this:
rcrgrl |
May 22 2006, 02:23 PM
none of those pics match. i think the triple square sounds right.
thanks guys! |
eeyore |
May 22 2006, 02:29 PM
If you live near El Cajon, or Nat'l City, try Vee Parts. They usually have the triple square tool.
tat2dphreak |
May 22 2006, 02:33 PM
they should be triple square, same size as the CV bolts...
I replaced mine with allen head, just like I did the CVs too... |
rcrgrl |
May 22 2006, 02:34 PM
Joe Ricard |
May 22 2006, 03:23 PM
Used to love going down to Vee's Great place always got what you need for air cooled stuff.
There was also a place out in Santee mostly dune buggy stuff but pretty good machinist. |
May 22 2006, 04:20 PM
"M8 triple square". Known to Bug guys as "the CV joint socket". Because it's the same as is used on the CVs. (Note that some 914s used regular bolts on the fan, while others used the triple squares.)
You don't need the special VW tool; I used three great big fender washers. After you take the fan off the hub, you can run the fan bolts into the hub far enough to pinch the washers between the bolts and the case. Then give the bolts about a half-turn each, one by one, and the hub will pop right off. Have something handy to catch the woodruff key, though, because it's easy to lose track of when it pops out! --DD |
So.Cal.914 |
May 22 2006, 04:30 PM
"M8 triple square". Known to Bug guys as "the CV joint socket". Because it's the same as is used on the CVs. (Note that some 914s used regular bolts on the fan, while others used the triple squares.) You don't need the special VW tool; I used three great big fender washers. After you take the fan off the hub, you can run the fan bolts into the hub far enough to pinch the washers between the bolts and the case. Then give the bolts about a half-turn each, one by one, and the hub will pop right off. Have something handy to catch the woodruff key, though, because it's easy to lose track of when it pops out! --DD Is there two types of impellers? I have only run into the type with the recessed holes for the tripple square bolts, hex bolt would not fit in holes. Is that an early impeller? |
Aaron Cox |
May 22 2006, 04:38 PM
"M8 triple square". Known to Bug guys as "the CV joint socket". Because it's the same as is used on the CVs. (Note that some 914s used regular bolts on the fan, while others used the triple squares.) You don't need the special VW tool; I used three great big fender washers. After you take the fan off the hub, you can run the fan bolts into the hub far enough to pinch the washers between the bolts and the case. Then give the bolts about a half-turn each, one by one, and the hub will pop right off. Have something handy to catch the woodruff key, though, because it's easy to lose track of when it pops out! --DD Is there two types of impellers? I have only run into the type with the recessed holes for the tripple square bolts, hex bolt would not fit in holes. Is that an early impeller? word. early and late or 914 and bus.... i have the early also. allen cap screws tho (IMG:style_emoticons/default/smile.gif) |
WRX914 |
May 22 2006, 05:24 PM
2.5 WRX STI hybrid powered beast Group: Members Posts: 782 Joined: 16-September 04 From: Las Vegas, NV Member No.: 2,771 Region Association: Southwest Region |
Torx can be found at Sears
Mueller |
May 22 2006, 05:30 PM
Torx can be found at Sears those bolts are NOT Torx (IMG:style_emoticons/default/headbang.gif) people don't read all of the posts and this is how people get screwed up by misinformation !!!!! |
Cap'n Krusty |
May 22 2006, 05:36 PM
if it has 6 points it's called a Torx. There you go, entering BAD information into the archives. It is NOT a torx. Porsche, and probably almost everyone else, didn't use torx fasteners in the 1970s. There are 2 different fasteners used to attach the fan to the hub on the T4 engine Some cars hace 8mm conventional machine screws, bolts, and some have 8mm bolts with triple square internal socket heads. The fans, BTW, are different as well. The Cap'n |
So.Cal.914 |
May 22 2006, 05:37 PM
Noticed that did ya. Can be aggrivating..
Cap'n Krusty |
May 22 2006, 05:38 PM
"M8 triple square". Known to Bug guys as "the CV joint socket". Because it's the same as is used on the CVs. (Note that some 914s used regular bolts on the fan, while others used the triple squares.) You don't need the special VW tool; I used three great big fender washers. After you take the fan off the hub, you can run the fan bolts into the hub far enough to pinch the washers between the bolts and the case. Then give the bolts about a half-turn each, one by one, and the hub will pop right off. Have something handy to catch the woodruff key, though, because it's easy to lose track of when it pops out! --DD Old fashioned "church keys" work even better than washers, Dave. Of course, the young'uns don't know what those are ............... The Cap'n |
Leo Imperial |
May 22 2006, 05:45 PM
Do you have to use so many cuss words? Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None |
This one - NOT a Torx
Dr. Roger |
May 22 2006, 06:03 PM
posts deleted. =-)
i hate being one of those mis-information people. LOL |
May 22 2006, 06:41 PM
Old fashioned "church keys" work even better than washers, Dave. True, but I had three fender washers lying around. I only had two church-keys, and one of them had plastic on one side and a magnet (and the metal clamping it on, very uneven!!) on the other. (IMG:style_emoticons/default/biggrin.gif) --DD |
Lo-Fi Version | Time is now: 17th May 2024 - 02:49 AM |
