Stock rear springs - how stiff? |
smontanaro |
May 23 2006, 08:38 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
I always see mention of 140# and 180# rear springs. I don't see any rear springs mentioned on Pelican's website. As a mental calibration, how stiff were stock 914/6 springs when new? Are stock springs fine for the street (assuming they aren't worn out)?
Thx, Skip Montanaro |
Aaron Cox |
May 23 2006, 08:42 PM
i believe between 70-90 lbs.....
DanT |
May 23 2006, 08:45 PM
(IMG:style_emoticons/default/agree.gif) I was going to say about 85#s
The street springs that Weltmeister has are about 100#s |
Aaron Cox |
May 23 2006, 08:47 PM
(IMG:style_emoticons/default/agree.gif) I was going to say about 85#s The street springs that Weltmeister has are about 100#s and are stock length, where the 140/180 are shorter...... |
DanT |
May 23 2006, 08:52 PM
Yes, I happen to have a pair of those particular springs laying around here somewhere. came off my 2.0L after I put on my Bils and 180s. (IMG:style_emoticons/default/biggrin.gif)
Aaron Cox |
May 23 2006, 08:56 PM
bills and 225's here (IMG:style_emoticons/default/tongue.gif)
flesburg |
May 23 2006, 09:10 PM
Senior Member Group: Members Posts: 506 Joined: 22-November 04 From: Pontiac, IL Member No.: 3,162 |
We have bilsteins with adjustable spring perches and 450# springs. Nice for setting ride height and not too stiff on the track. We are not using rear anti-sway bar.
TravisNeff |
May 23 2006, 09:36 PM
I believe the spring rates are 60-80lbs. They are differentiated by paint marks on the springs.
Eric_Shea |
May 23 2006, 10:21 PM
I really haven't seen a definitive answer on this and I wondered too when I had my -6.
The one I've heard the most is 90lbs for a -6. Anyone (of our curators) have the answer... I mean, "the" answer? |
Brad Roberts |
May 23 2006, 10:58 PM
Here is what the factory has to say about the stock springs for the 4cyl and the 6cyl
4cyl is on the left side 6 on the right. There has to be some math that can be done to figure out the rates? |
Mueller |
I'm too lazy/tired to figure it out...but if you find a spring calculator, plug in the numbers from the column on the far right for /6 springs (factory manual)
(/4 springs on left column) |
Brad Roberts |
May 23 2006, 11:03 PM
Brad Roberts |
May 23 2006, 11:05 PM
Mike?
What are you doing on Ferreri chat? LOL B |
BigDBass |
May 23 2006, 11:31 PM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
Brad Roberts |
May 23 2006, 11:36 PM
Maybe he is developing some jack stands for them?
B |
Lo-Fi Version | Time is now: 15th May 2024 - 01:25 AM |
