smontanaro
May 23 2006, 08:38 PM
I always see mention of 140# and 180# rear springs. I don't see any rear springs mentioned on Pelican's website. As a mental calibration, how stiff were stock 914/6 springs when new? Are stock springs fine for the street (assuming they aren't worn out)?
Thx,
Skip Montanaro
Aaron Cox
May 23 2006, 08:42 PM
i believe between 70-90 lbs.....
DanT
May 23 2006, 08:45 PM
I was going to say about 85#s
The street springs that Weltmeister has are about 100#s
Aaron Cox
May 23 2006, 08:47 PM
QUOTE(Dan (Almaden Valley) @ May 23 2006, 07:45 PM)
and are stock length, where the 140/180 are shorter......
DanT
May 23 2006, 08:52 PM
Yes, I happen to have a pair of those particular springs laying around here somewhere. came off my 2.0L after I put on my Bils and 180s.
Aaron Cox
May 23 2006, 08:56 PM
bills and 225's here
flesburg
May 23 2006, 09:10 PM
Click to view attachmentWe have bilsteins with adjustable spring perches and 450# springs. Nice for setting ride height and not too stiff on the track. We are not using rear anti-sway bar.
TravisNeff
May 23 2006, 09:36 PM
I believe the spring rates are 60-80lbs. They are differentiated by paint marks on the springs.
Eric_Shea
May 23 2006, 10:21 PM
I really haven't seen a definitive answer on this and I wondered too when I had my -6.
The one I've heard the most is 90lbs for a -6.
Anyone (of our curators) have the answer... I mean, "the" answer?
Brad Roberts
May 23 2006, 10:58 PM
Here is what the factory has to say about the stock springs for the 4cyl and the 6cyl
4cyl is on the left side 6 on the right.
There has to be some math that can be done to figure out the rates?
Mueller
I'm too lazy/tired to figure it out...but if you find a spring calculator, plug in the numbers from the column on the far right for /6 springs (factory manual)
(/4 springs on left column)
Brad Roberts
May 23 2006, 11:03 PM
Found it
Brad Roberts
May 23 2006, 11:05 PM
Mike?
What are you doing on Ferreri chat? LOL
B
BigDBass
May 23 2006, 11:31 PM
QUOTE(Brad Roberts)
Mike?
I was wondering the same thing.
Brad Roberts
May 23 2006, 11:36 PM
Maybe he is developing some jack stands for them?
B
