How to remove the engine lid mount bracket |
terrymason |
May 23 2006, 09:05 PM
Member Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 |
I just got this from restoration design:
(IMG:http://www.restoration-design.com/partspics914/images/P343.jpg) What's the best way to remove the original? Only thing I can think of is a chisle / pry bar, and just beat the old one off. Any better recommendations? |
RustyWa |
May 23 2006, 09:06 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
Drill the spot welds out.
Mueller |
May 23 2006, 09:28 PM
I just got this from restoration design: (IMG:http://www.restoration-design.com/partspics914/images/P343.jpg) What's the best way to remove the original? Only thing I can think of is a chisle / pry bar, and just beat the old one off. Any better recommendations? you are scary (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/biggrin.gif) ditto on the drill and grind method....good chance that you'd screw up the firewall by beating on it.... (IMG:style_emoticons/default/smash.gif) |
bd1308 |
May 23 2006, 09:54 PM
just let it rust out...
b |
Eric_Shea |
May 23 2006, 10:14 PM
I don't recall if that's mounted on a double-walled portion or not. If not, take off the back pad and drill the spots from there. Use the holes to rosette weld the new one on. Reinstall the back pad and zoom-zoom.
If it is mounted on a double-walled portion then the only way would be to drill through the piece itself (which is about twice as thick). I would then drill a couple of holes in the new piece and rosette weld it. I think it comes out a little neater that way. For pure functionality you could weld around the edges as well... either way works as long as you get penetration. You could also use a carbide cut-off wheel on a Dremel. Those little suckers rock and, they're small enough that they can be easily handled. (Good one Britt (IMG:style_emoticons/default/lol3.gif)) |
Lo-Fi Version | Time is now: 15th May 2024 - 09:21 AM |
