Rocker Rivets |
Rocker Rivets |
Pat Garvey |
May 24 2006, 07:04 AM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
(IMG:style_emoticons/default/huh.gif)
Some discussion recently about the rocker panel/door sill rivets, indicated the white ones are NLA. I bought a large supply of these in the eraly 80's, because I remove the rockers every couple of years for cleaning & replace them because they seem to be good for one use only. I have 4 left & need to do my removal/clean operation, so I obviously will have to change. I'm assuming that the factory replacement rivets are readily available, but color are they? Anyone get these recently? What's pricing like? Do they do a job equal to the orig's, or are they better (better, I hope)? |
sixerdon |
May 24 2006, 07:25 AM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
Pat,
The translucent/clear ones seem to be the ones still available. I had to use them on one of my sixes when I was restoring it some 7 years ago. I think I bought them from Stoddard at the time. I still see them listed with Performance Products so I'm sure they are out there. I was pleased with the design to match up with original whites or blacks. It's just a neutral color that you'll have to deal with by dying or painting them. I have done neither on my six. Visually they look white at 1st glance, but they are not the original white. I do not fully remove my rockers for that reason. I just remove the lower screws and pull back the panel without disturbing the rivets. If it's dry underneath, then you can use an air compressor to blow it out. Don |
Lo-Fi Version | Time is now: 29th May 2024 - 06:38 PM |
