Okay, it's running again, but..., 1.8 L-Jet |
jd66921 |
May 24 2006, 02:27 PM
Member Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 |
Okay, I got my car running again, but not perfectly. But, I am confused!
Everyone told me to check for vacuum leaks, which I did. I got one of the pipes to the S boot snapped in. The other one is pretty tight anyway. Not pefectly sealed yet. This morning, I was checking the car over. I pulled spark plug #4 and found it wet with gas?? I would have thought that the car would have been lean with air leaks. If I had air leaks, there would be too much air. Also, the air flow sensor would not open so the mixture would not richen? Am I missing something? I did cap off all the lines from the air box. Anyway, I pulled the electrical connector off the cold start valve, and tried it. It started after about 5 seconds. It ran for a minute, and then died. It would restart, but die pretty quickly. I stopped to think about all of this. Three heat exchangers were hot, #2 was not. That plug always looked good/lean? Maybe #2 has an injector problem? I want to fix that cylinder first. How do you remove the injectors? I've looked but haven't found anything. Must be easy?? Do I NEED a new gasket? Then I can work on the engine dying problem. Maybe it will idle on four cylinders? Nah, can't be that easy! Obviously, I will start to reconect everything to see if anything is causing a problem, but I am excited again! How far out should the idle screw be on the throttle body? One turn, more? Thanks for your thoughts, Jeff |
Lo-Fi Version | Time is now: 17th May 2024 - 01:33 AM |
