ITS ALIVE! AND IT HUNGERS FOR SOULS, Scary |
Dr Evil |
May 24 2006, 04:22 PM
It is running and sounds frightening
More later, gotta go to an engagement. I know, I'm a trease. |
Aaron Cox |
May 24 2006, 04:37 PM
i knew you could do it....
you built it after all..... how long till it blows up? (IMG:style_emoticons/default/tongue.gif) |
Leo Imperial |
Do you have to use so many cuss words? Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None |
(IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/jsharp.gif)
Doooode cooool |
Gint |
May 24 2006, 04:59 PM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Dammit! What a blue-ball...
jimkelly |
May 24 2006, 07:38 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
What a relief (IMG:style_emoticons/default/thumb3d.gif)
Allan |
May 24 2006, 07:42 PM
Wat to go Mike!!!!!!!!!
Keep the adrenalin flowing when you go to anatomy class and throw cadaver parts all over the room..... |
fitsbain |
May 24 2006, 08:17 PM
Ask me if my car has rust!!! Group: Members Posts: 619 Joined: 25-February 06 From: Pittsburgh PA Member No.: 5,634 |
Good job Dr E!!!
I didn;t think you would get it done before our now pushed back till the 24th of june get together. You did say it would be done by Saturday and of course you did it. |
plas76targa |
May 24 2006, 08:34 PM
Senior Member Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region |
So.Cal.914 |
May 24 2006, 09:49 PM
Good deal. (IMG:style_emoticons/default/burnout.gif)
You didn't say what the problem was. " I gots ta know." (IMG:style_emoticons/default/smoke.gif) |
Series9 |
May 24 2006, 10:10 PM
I can't believe you're wasting your time on Medschool when I need door panels for Liz....
But seriously, congratulations. |
Dr Evil |
May 24 2006, 11:24 PM
New price for door panels, $1000 (IMG:style_emoticons/default/wink.gif) Doctor rates, ya know?
Ok here is the story: Read my other posts on what was going on in order before today. Today I went out and unplugged the cold start valve (what I though I already did, but didn't) and plugged in the warmup regulator (what I actually unplugged the first time). Why? Because the CSV was flooding the hell out of my engine and it would not start. So I did this and it would seem to start immediately, but as soon as I depressed the pedal it woudl die, "vroom, stop." I could still smell a buch of gas so I decided to remove all of the spark plugs and I used my hot air gun, on cold of course, to dry all of the cylinders out. I reinstalled, closed the idle set screw almost all of the way and gave it a go. I got it running rough and it was smoking pretty good, but I gave it gas and eventually it started to smooth out a bit and I got it up to 3k. With both doors open and a light wind I was still engulfed in a cloud of freshly burnt off stickers from the bursche exhaust, and the little fuel in the header plus other things. It sounded angry, powerful and hungry. I got it smoothed out after some tweeking and it will even idle on its own (IMG:style_emoticons/default/biggrin.gif) Now the next problem...... I quickly noticed the new puddle of oil under my drivers side...)*(&)&)(&! This has been an on going problem as I noticed the mating surface for the lower valve cover has dents in it (WTF!) and was leaking before so I sealed it with some tri-bond 1211. It worked, alomost. Ya see, the clearance between my oil cooler and the valve cover is very tight (as oppsed to before when it was non existenet) and when I put it on I must have remived some sealant. So, I have some silicone coated valve cover gaskets on their way as of tonight.....I hope they get here soon. To add insult to injury, the oil line needs to be tightened which requires removing the left header....always something. Sooooo, maybe this weekend, if the parts arive, I will move it out off the garage for the first time in a year and it will be moving under its own power for the first time in about 3 years. The engine sounds scary running in the garage, though. |
Dr Evil |
May 24 2006, 11:25 PM
Matt, 6/24 = BBQ in Pittsburg. See the thread here.
So.Cal.914 |
May 25 2006, 01:46 AM
I read every thread and every post... Cool,,, now you will be able to enjoy the
the summer, in style. Have Fun. (IMG:style_emoticons/default/smoke.gif) |
root |
May 25 2006, 06:06 AM
Two Wheeled Type4 Completed! Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None |
You better hang on tight when you take it out for your first test drive.
It's got twice the horsepower and half the weight of your diesel cruiser..... (IMG:style_emoticons/default/driving.gif) Congrats, especially on the idle ability...that's assume. |
root |
May 25 2006, 06:07 AM
Sorry...Awesome! (IMG:style_emoticons/default/burnout.gif)
JerryP |
May 25 2006, 06:22 AM
member Group: Members Posts: 314 Joined: 8-October 03 From: Berwyn, PA Member No.: 1,225 |
Gint |
May 25 2006, 07:05 AM
Now the next problem...... I quickly noticed the new puddle of oil under my drivers side...)*(&)&)(&! This has been an on going problem as I noticed the mating surface for the lower valve cover has dents in it (WTF!) and was leaking before so I sealed it with some tri-bond 1211. It worked, alomost. Ya see, the clearance between my oil cooler and the valve cover is very tight (as oppsed to before when it was non existenet) and when I put it on I must have remived some sealant. So, I have some silicone coated valve cover gaskets on their way as of tonight.....I hope they get here soon. Grats man! I'm gonna need your help when I install my 2.7 CIS. (IMG:style_emoticons/default/wink.gif) Didya see my last reply to your Next problem....now what, Gonna haveta bend something thread? You never answered that question. The valve covers need to have some of the stiffening rib area at the rear of the covers milled off when /6 motors are installed in a 914. Especially on the left side. |
rick 918-S |
May 25 2006, 07:13 AM
Hey nice rack! -Celette Group: Members Posts: 20,441 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Great to hear. I would still remve the cold start valve and check it. It may be leaking.
brant |
May 25 2006, 08:32 AM
914 Wizard Group: Members Posts: 11,618 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
congrats Mike!
great job! brant |
TROJANMAN |
May 25 2006, 09:22 AM
Looks nice in pictures......... Group: Members Posts: 5,259 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
(IMG:style_emoticons/default/av-943.gif) wait.............. (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 08:26 PM |
